When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by fh_freese
at 2024-07-10 11:40:36
Point:500 Replies:15 POST_ID:828951USER_ID:11849
Folks,
Below you will see in the formula bar an IF statement that is not getting what I would like.
My objective is this:
If there's a #DIV/0! error in cell O6, in cell P6 I would like to do this:
Replace the #DIV/0! in cell O6 with "Error" and in P6 have a remark saying "Please refer to Remarks". If no #DIV/0! error in O6 then in P6 have a remark saying "OK"
Author: fh_freese replied at 2024-07-10 15:23:57
OK...now I understand and I like the idea of first providing data they can work with. I think I'll keep the Try Again forcing them to reenter the formula (of course they could simply change the values and it recalculates automatically, unless I disabled automatic recalc for each sheet. Then I would have to .......rats Martin! I'm making things hard for me. I'll have to rest on this.
Expert: MartinLiss replied at 2024-07-10 15:08:29
I know. My last two posts are just suggestions about what you could do when refreshing the sheet so that the data you put there would show up again after the user fooled around, left the sheet and came back, or clicked the TryAgain button. If however you were going to leave N6:N10 blank then my suggestions don't apply and in that case you might as well get rid of the TryAgain buttons.
Author: fh_freese replied at 2024-07-10 15:02:38
I accepted the second post, at this time.
Expert: MartinLiss replied at 2024-07-10 14:50:08
And instead of putting that code in the Activate event and the TryAgain sub change the Activate event to
Private Sub Worksheet_Activate() TryAgain ActiveSheet.Range("O6").SelectEnd Sub 1:2:3:4:
Expert: MartinLiss replied at 2024-07-10 14:44:40
Consider changing your Worksheet_Activate events to something like this (for the AVERAGE sheet).
Private Sub Worksheet_Activate()With Worksheets("Average") .Range("O6").ClearContents .Range("N6") = 8 .Range("N7") = 7 .Range("N8") = 9 .Range("N9") = 6 .Range("N10") = 10End WithActiveSheet.Range("O6").SelectEnd Sub 1:2:3:4:5:6:7:8:9:10:11:
Author: fh_freese replied at 2024-07-10 14:26:10
You're a good man Martin. This problem was just solved with my last post. I've decided to move away from the Correct/Incorrect.
However, I was preparing another post to you regarding printing we spoke of the other day.
Expert: MartinLiss replied at 2024-07-10 14:22:16
Try this formula
=IF(OR(O6="",O6=0), " ", IF(O6=AVERAGE(N6:N10),"Correct","Incorrect"))
Author: fh_freese replied at 2024-07-10 12:22:19
My pleasure, however, I spoke a little early. I'm having a problem still but haven't figured out how to solve it yet
Expert: duncanb7 replied at 2024-07-10 12:19:08
Author: fh_freese replied at 2024-07-10 12:17:32
great job...thank you
Author: fh_freese replied at 2024-07-10 12:16:52
I think you all got it!
Expert: duncanb7 replied at 2024-07-10 11:55:01
166 points EXCELLENT
IFERROR(AVERAGE(N6:N10),"ERROR") putting on cell O6
and
IF (O6="ERROR","please refer to remark","OK") putting on cell P6
and
Expert: Randy Poole replied at 2024-07-10 11:54:38
167 points EXCELLENT
Ok and for the 2nd part in P6 place
=IF(O6="Error","Please refer to Remarks","Ok")
Expert: imnorie replied at 2024-07-10 11:50:57
You can't use a formula to place a value in another cell.
Expert: Randy Poole replied at 2024-07-10 11:50:55
The first part should be:
=IFERROR(AVERAGE(N6:N10),"Error")
Try that and see if returns what your looking for
