When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by theideabulb
at 2024-07-10 07:51:00
Point:500 Replies:9 POST_ID:828948USER_ID:11847
Regular Expressions;;
I am looking for regex to help remove a section of text. Here is the HTML
<p class="online-instore-icon online NSFS"> <span class="screen-reader-only">Available </span> Not sold in stores</p><p class="online-instore-icon online NSFS"> <span class="screen-reader-only">Available </span> Not sold in stores</p><p class="online-instore-icon online NSFS"> <span class="screen-reader-only">Available </span> Sold in stores</p><p class="online-instore-icon online NSFS"> <span class="screen-reader-only">Available </span> Sold in stores</p> 1:2:3:4:5:6:7:8:9:10:11:12:
This produces text that looks like this:
Available Not sold in storesAvailable Sold in storesAvailable Sold in storesAvailable Not sold in storesAvailable Sold in stores 1:2:3:4:5:
I basically need to remove the word 'Available'
In the end it should really just be this.
Not sold in storesSold in storesSold in storesNot sold in storesSold in stores 1:2:3:4:5:
Expert: duncanb7 replied at 2024-07-10 10:10:24
Author: theideabulb replied at 2024-07-10 10:01:19
Thank you
Expert: duncanb7 replied at 2024-07-10 09:49:18
you need this regex for whole html page(not just one span tag and classname), Right ?
/(<span class="screen-reader-only">Available(.*)</span>)/is
And
/(<span class="screen-reader-only">Sale Price(.*)</span>)/is
And
Expert: ozo replied at 2024-07-10 08:55:26
#!/usr/bin/perl
$_=<<END;
Sold in stores</p>
Sold in stores</p>
END
s#<span class="screen-reader-only">.*?</span>##g;
print;
$_=<<END;
Sold in stores</p>
Sold in stores</p>
END
print;
Author: theideabulb replied at 2024-07-10 08:37:48
All i need is find any type of element that has this: class="screen-reader-only"
I see in the HTML code that there is also:
<p class="price price-label">
<strong class="screen-reader-only">
Sale Price</strong>
$24.99
</p>
I need to remove that Sale Price text as well.
So I am hoping there is a way to find these spots that have that class and remove them so I can grab the other text that is left over
Sale Price</strong>
$24.99
</p>
Expert: duncanb7 replied at 2024-07-10 08:32:24
Could you explain more ?
Where or how you get html page code you attached ?
You mean javascrip regex code running on the html code, that will take out all "Available" ?
Regex is javascript code you mean or you want ?
If you write down step by step what you want that will be faster to solve your issue
Author: theideabulb replied at 2024-07-10 08:27:13
its for a scraper. The HTML that comes back is what I have up there. I would like to clear out that 'Available' section of text so that I can just grab what I need for the availability status.
Expert: duncanb7 replied at 2024-07-10 08:23:43
COuld you explain you want to do regex, In javascript or php script programming ?
Could you use CSS style to hide "Available" in html page such as follows
Hope understand your question completely.If not, please point it out.
Expert: Kimputer replied at 2024-07-10 07:57:33
Try this
