When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Rayne
at 2024-07-09 21:53:11
Point:500 Replies:11 POST_ID:828941USER_ID:11838
Microsoft Office Suite;MS SharePoint;Microsoft Excel Spreadsheet Software
Hello All,
In the previous share point version (earlier than 2013) - if you upload a excel file to share point site -
opening the SharePoint in internet explorer - and then viewing that same excel file ->> user will get a drop down saying "Open with excel"
BUT, when I am in new SharePoint 2013 site - i don't see that option as one of the options.....for opening the excel file
please help
is this something admins can enable or something IT needs to do at their end to make this feasible?
Thanks a million
please help
Thanks a million
Expert: duncanb7 replied at 2024-07-10 22:56:34
Author: Rayne replied at 2024-07-10 22:49:03
Thank you Duncan, I will try this
Expert: duncanb7 replied at 2024-07-10 22:21:11
You can try
1)
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Server/MS-SharePoint/Q_28469478.html#a40179651
the link in my first post that will assist you to switch to 32-bit iE
OR
2) reset IE default setting
If both item is not okay , try to do next item (3) that may need 32-bit IE(i guess)
enabled the following add-ons
- SharePoint Export Database Launcher
- SharePoint OpenDocuments Class
- SharePoint Spreadsheet Launcher
- SharePoint Stssync Handler
OR
Author: Rayne replied at 2024-07-10 22:15:37
looks like we may getting somewhere and thanks for indicating....where do i need to implement that - can this be done within sharepoint UI or the IT has to do it on their end?
Expert: duncanb7 replied at 2024-07-10 22:10:56
-1 Could you try to reset default IE setting ?
-2 Have you enabled the following add-ons?
it seems you need to switch to 32-bit IE to solve this issue
Author: Rayne replied at 2024-07-10 21:54:26
Author: Rayne replied at 2024-07-10 21:54:02
Hello Duncan,
its weird, I do have admin access but I don't see it. In the old SharePoint site (not 2013), I can do this but in the new 2013 SharePoint - this option "edit with Microsoft office excel" is missing or unavailable. Please the attached image.
Expert: duncanb7 replied at 2024-07-10 21:32:48
it seems user permission issue.
Take a look at Microsoft link
http://social.technet.microsoft.com/Forums/sharepoint/en-US/2790eea7-70f3-4dae-bc36-044857769e22/open-in-excel-tab-is-missing-in-excel-services
in that link , please also check this "Managing Workbooks, and User Permissions and Permission Levels"
http://technet.microsoft.com/en-us/library/cc721640(office.14).aspx
Hope it will solve your isssue
From your posts, I simplify your isssue is "Missing Excel tab on sharepoint", Right ?
Author: Rayne replied at 2024-07-10 21:22:40
duncanb7
I think that's not my issue. I indicated "open with Microsoft Excel" as a option that you would get from share point site - when you are clicking on the excel file within a sharepoint site....make sense?
Expert: duncanb7 replied at 2024-07-10 01:56:53
Are you using 64 or 32-it mode of IE ?
There is similar (be reminded just similar not the same) issue that is related to IE mode
Author: Rayne replied at 2024-07-09 21:55:05
also, if i make any changes to any excel file and upload it to the new share point - it asks like 50 question before the file can be uploaded - how to disable this stupid thing or limit the questions asked - once again - who can disable it? admin user or IT?
