When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by AXISHK
at 2024-07-04 02:53:21
Point:500 Replies:6 POST_ID:828934USER_ID:11834
MS SharePoint;;
Some Remote users complain that the "Open with Explorer" is not available when accessing our SharePoint 2010. Any idea ? What' s the potential problem that we can take a look.
Tks
Tks
Expert: duncanb7 replied at 2024-07-08 20:54:28
Author: AXISHK replied at 2024-07-08 19:19:25
Tks
Expert: duncanb7 replied at 2024-07-06 21:03:52
For window 8:
In prior versions of 64-bit Windows there were two versions of Internet Explorer that came as part of the operating system. One was the regular 32-bit version as well as a native 64-bit version. An ongoing problem with 64-bit Internet Explorer is that plugins designed for the 32-bit version aren’t compatible with it but you still might fancy using it on Windows 8.
So, here’s how you enable it:
Open Internet Explorer 10 on the desktop,
Click the Settings cog up the top right corner of the window,
Click the Advanced tab,
Scroll down until you see Enable Enhanced Protected Mode* and tick the box next to it,
Click OK,
Restart Internet Explorer.
OR other method for window 8:
take a look at this link for try to use 32-bit on Window8
http://kb.zmodo.com/index.php?action=artikel&cat=1&id=67&artlang=en
Click OK,
Author: AXISHK replied at 2024-07-06 18:56:39
How to switch the IE to 32bit ? Some users are working on Window 8...
Tks
Tks
Expert: duncanb7 replied at 2024-07-04 03:16:12
What is version of IE are you using and window system ?
it might solve the issue if switching to 32-bit IE
Expert: Jamie McAllister MVP replied at 2024-07-04 03:09:21
I've seen users open the 64bit version of IE by accident, and that removes the Open with Explorer option.
