When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by c7c4c7
at 2024-07-01 23:30:59
Point:0 Replies:9 POST_ID:828928USER_ID:11828
Windows Server 2008;;
The server has all updates applied. The machine started hanging up and when we looked the machine was running at 100% CPU occupancy. Eventually found that there were numerous svchosts being kicked off 40-50 of them
Running Process explorer the svchosts are all running syswow64.
Opened up the location of the program using task manager and ran a scan against syswow64, but it does not appear to be infected.
I also generated a .dmp file from the task manager of the svchost causing the problem but do not know how to work with this type of .dmp file I am only familiar with the ones created by a blue screen.
I did find a couple of files in the default users startup folder that were identified as viruses from doing a scan of the machine. They were qiutzi.exe suaze.exe, they were cleaned up but problem persists
I searched online for references to the above two files but did not find anything that would help.
The svchost's get generated after the machine is up and running for about 30 minutes, I don't see anything getting kicked off and am running out of ideas.
Any ideas?
Any ideas?
Author: c7c4c7 replied at 2024-07-08 02:16:40
There was no solution
Author: c7c4c7 replied at 2024-07-03 17:00:59
A miracle! the problem disappeared all by itself.
Not sure I like that solution but I will have to wait and see what happens
Author: c7c4c7 replied at 2024-07-02 13:31:37
Sorry misspoke on that last post, ignore it
Author: c7c4c7 replied at 2024-07-02 13:24:02
Looking at another server, syswow64.exe doesn't exist. SysWow64 is a folder on that machine, anybody got any feedback on that?
Expert: duncanb7 replied at 2024-07-02 07:47:49
You can try it in any way, be reminded your system could be recovered by
Window Recovery Software on your PC windows system that once you
have issue during your try, you can get back the system status to date that
is before any try or test
Author: c7c4c7 replied at 2024-07-02 07:36:29
It looks like syswow64 is used to enable 32 bit apps run on a 64 bit machine, is that true?
Can I remove/rename temporarily syswow64 and see what fails? There is very little running on this machine. SQL SERVER, Paperclip and that's it.
It looks like when the processes start generating they occurr about 1 every 30 seconds.
How do I see what is generating these processes.
Expert: duncanb7 replied at 2024-07-02 07:32:02
Just copy and paste issue. This is right one
http://www.neuber.com/taskmanager/process/svchost.exe.html
Author: c7c4c7 replied at 2024-07-02 07:26:49
Duncan, received URL not found from your link
Expert: duncanb7 replied at 2024-07-02 01:22:58
If the svchosts.exe cause high CPU usage, it may be caused by the automatic
window update from which it may create some hidden malware on your computer
that might change your window registry key.
Please use the following link to check the issue with free svchosts analyzer
http://www.neuber.com/taskmanager/proces...
Be reminded. The svchosts.exe is located at c:WinodwsSystem32 and delete all
other svchosts.exe file at other path. You can search those problem svchosts files
at Window Explore
at Window Explore
