When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jskfan
at 2024-05-25 03:08:41
Point:500 Replies:6 POST_ID:828925USER_ID:11761
Network Routers;;Cisco PIX Firewall
http://ccnpsecurity.blogspot.com/2011/10/connection-limits-through-cisco-asa.html
Reading the above article, I was trying to understand the Terminology used in Class Map, but can not get grasp of the following commands:
set connection embyronic-conn-max
set connection per-client-embryonic-max
set connection timeout embryonic
set connection timeout half-close
set connection timeout dcd retry_interval
[max_tries]
Any help ail be very much appreciated..
Thank you
[max_tries]
Thank you
Author: jskfan replied at 2024-06-07 03:17:18
Author: jskfan replied at 2024-06-07 03:14:36
I need just the simple meaning:
what do they mean by dcd?
what do they mean by half-close ?
Author: jskfan replied at 2024-05-31 07:32:42
As you explained , it seems like "embryonic connection" relates to Sync (first handshake way) ??
Expert: PeteLong replied at 2024-05-25 11:19:01
TCP is a three way process (Syn, Ack, and SynAck) as soon as a client makes a connection through the firewall, it opens an 'embryonic connection' that waits for the second part of the conversation (the Ack), once the embryonic connection sees all the parts of the conversation, it becomes a connection.
Author: jskfan replied at 2024-05-25 11:15:43
Terminology is weird…
what do they mean by embryonic ?
thanks
thanks
Expert: duncanb7 replied at 2024-05-25 03:34:00
You mean those command you posts above that don't react(not get grasp), right ?
Did you activate the policy map on one or more interfaces ?
Command:
service-policy policymap_name {global | interface interface_name}
for example:
service-policy CONNS interface outside
Take a look at this if need for similar CISCO device reference
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/conns_connlimits.html
Hope understand your question completely, if not, please point it out
Command:
for example:
