When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by peispud
at 2024-05-24 17:22:04
Point:500 Replies:8 POST_ID:828922USER_ID:11822
I am using Office 365 / Excel
I need this to work in an IPAD Air, so I presume VBA is out of the question.
Here is a formula. Here is a problem. The following formula will be found in B1, B2, B3 etc... referencing the cell to the left.
=IF(A1=TRUE,CHOOSE(RAND()*10+1,1,2,3,4,5,6,7,8,9,10),"")
As things are now, if A1 = true, then the value in B1 will change every time a sheet calculation is done, no matter what the trigger for the sheet recalculation.
I want the value of B1 to recalculate only when the cell A1 has exited the edit mode.
Thank you.
Thank you.
Author: peispud replied at 2024-05-28 15:31:48
I haven't tried Rob Henson's solution yet, the this is the kind of innovative idea that I was hoping for.
I will try this. Thank you all
Aubrey
Aubrey
Expert: Rob Henson replied at 2024-05-27 02:17:30
500 points AVERAGE
There is a third option for Calculation - "Automatic except for Data Tables".
Maybe setting your range to a Data Table and using this option will prevent it from Recalculating.
Rob H
Rob H
Expert: Glenn Ray replied at 2024-05-25 14:52:16
Unless there is an option to change the calculation mode from "Automatic" to "Manual" AND there is some keyboard shortcut equivalent to the [F9] key, I don't think this will be possible without VBA.
Author: peispud replied at 2024-05-25 14:25:47
set the value of A1 = true
Set the following formula in B1 =IF(A1=TRUE,CHOOSE(RAND()*10+1,1,2,3,4,5,6,7,8,9,10),"")
The worksheet will recalculate and cell B1 will resolve to a value.
Now go to cell D5 : Enter any new value there and watch cell B1. The value will change.
I want Cell B1 to only change when cell A1 has changed. I need to do this without VBA.
I may not get a solution to this dilemma here, but that is ok. If anyone can help with this though, that would be great!
Expert: duncanb7 replied at 2024-05-25 04:49:07
Is there icon for formulas on Excel?
click the Formulas tab > Calculation Options button, then check "Automatic"
Author: peispud replied at 2024-05-25 03:38:52
I will look at the MSDN article more closely when I have more time. I did have a quick look at it. In my analysis (quick read), the solution proposed there requires the use of VBA. I cannot use VBA on an Ipod Air.
I don't think that the answer is there.
Aubrey
Aubrey
Expert: duncanb7 replied at 2024-05-24 17:52:26
There is a few article about Excel recalculation in google search, there is one
at this Microsoft site.More or less is Excel2003/2007 similar to Office365/Excel for Manual
recalculation at the bottom of the page , at
http://msdn.microsoft.com/en-us/library/bb687891(v=office.12).aspx
Hope understand your question completely, if not , please point it out
Expert: Glenn Ray replied at 2024-05-24 17:38:08
I'm guessing setting the worksheet to Manual calculation (in Options) and then forcing a manual refresh ([F9] in Windows, same on Macs) won't work for you.
I can say that the following formula will achieve the same result in a simpler manner:
=IF(A1=TRUE,RANDBETWEEN(1,10),"")
-Glenn
-Glenn
