When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by MARSPATH
at 2024-05-23 14:32:35
Point:500 Replies:3 POST_ID:828918USER_ID:11819
Spreadsheet Software;;
Excel 2007 .xlsx file cells A4 through A72 contains as part of string 'E:SitesLee Academy for the Arts'
I want to replace' E:SitesLee Academy for the Arts' with 'http://schoolforthearts.org/'
How do I get this to work? e.g.
replace (A1...A71, "E:SitesLee Academy for the Arts", "http://schoolforthearts.org/") - this does not work in f(x) cell.
Expert: duncanb7 replied at 2024-05-24 17:21:07
Author: MARSPATH replied at 2024-05-24 14:25:43
Got me started in the right direction, thanks
Expert: duncanb7 replied at 2024-05-23 16:45:18
You may need to do it in VBA on Excel for range operation from a1:a100
If in Excel cell operation, try this and need to drag the cell from A1 to A100 on Excel sheet
and using find() and if() function
A1 B1
E:SitesLee Academy =if(ISERROR(find("E:SitesLeeAcademy",A1,1))=TRUE,"","http://schoolforthearts.org/","")
A1 B1
