When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Mark_Co
at 2024-04-11 21:20:38
Point:500 Replies:4 POST_ID:828916USER_ID:10
PHP Scripting Language;Linux;Scripting Languages
I am trying to delete a file using rm -rf first.php and i keep getting this error:
Can someone please tell me how to remove the file? Thanks.
Expert: skullnobrains replied at 2024-04-13 08:53:19
125 points EXCELLENT
++Gerwind : being root or toying with access rights will not make a difference if the filesystem is mounted read-only
you can easily find the mountpoint using "df filename" and mount options using the mount command without arguments.
if you want to go the lazy way, copy-paste this
you may or may not be able to remount the filesystem read-write ( -o rw ) depending on the circumstances. for example a cd will not be mountable rw.
Expert: Gerwin Jansen replied at 2024-04-12 00:05:05
The file you are trying to delete is on a read only file system. Looks like it's on a SAN/NFS location that has been mounted read-only.
Look up the folder where the file resides with "ls -l", then verify with "mount" where that folder is mounted. You either have to re-mount that folder as read-write or (s)ftp to the SAN/NFS location and delete the file there.
Expert: duncanb7 replied at 2024-04-11 22:37:31
using linux command, ls -la first.php you can see the group and owner of the file.
If you have root account and password to access (su root or su on your login shell)
You can use root account and passwd to delete it.
Or you can do it first (change group and owner of the file)
chgrp -R -v youraccount first.php
chown -R -v youraccount first.php
And then delete it
Be reminded, using your account to ftp, putty send (pscp.exe), edit,create,write, read or delete the first.php or New file which is owned by your account
And then delete it
Expert: omarfarid replied at 2024-04-11 21:27:54
If you are not the owner of the file or the dir in which the file is in then you can not delete it.
Run the script as root,
