When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by JeffBeall
at 2024-04-07 10:18:08
Point:500 Replies:12 POST_ID:828915USER_ID:11816
Windows Networking;Windows 7;Miscellaneous Networking
I am looking for some good windows troubleshooting tools, and started messing around with the
netsh
command - as i am playing with this, I got the impression that this might be a good way to look into networking problems.
if this is a good assumption, what are the best netsh commands to use when looking into networking problems?
netsh
Author: JeffBeall replied at 2024-04-08 16:47:24
thank you for the help
Author: JeffBeall replied at 2024-04-07 13:23:36
Thank you!
I forgot to mention nslookup, but i am also not familiar with portqry
also, I agree
"Having a set of tools like a screwdriver and a hammer is good, but not worth much without some deep insight into the mechanics, and sophisticated knowledge of diagnostic methods"
what I do is, for something like nslookup, yesterday I was googling best practice using nslookup and that led to DNS. So not only do I learn about nslookup, but also about DNS. So I will just do the same for portqry, and probably discover new insights into how windows uses ports.
also, I agree
Expert: McKnife replied at 2024-04-07 13:15:36
166 points EXCELLENT
:) Sure, understood.
There are some that one has to know:
telnet.exe, nslookup.exe, Portqry.exe, portping.exe instantly come to my mind. The latter from here: http://www.tkolb.de/portping-13-36.html , the othes built-in/Microsoft.
Expert: Qlemo replied at 2024-04-07 13:13:08
NetMon is the predecessor of Message Analyzer, and like WireShark,
I agree to what McKnife wrote. Having a set of tools like a screwdriver and a hammer is good, but not worth much without some deep insight into the mechanics, and sophisticated knowledge of diagnostic methods.
Author: JeffBeall replied at 2024-04-07 13:07:22
I didn't intend for it to sound like i thought there was a tool that would find everything i might run into.
I mostly use, ping, then ipconfig
and they for the most part, give me a picture of what is happening. My goal was to see if there were other tools that i'm not familiar with that i could add to my "toolbox", like I mentioned earlier
"i learned that netsh wouldn't be a good tool, but for example, i haven't heard of ms netmon. so i could look at that."
so I might have found another helpful tool in ms netmon.
Expert: McKnife replied at 2024-04-07 12:41:27
Jeff, diagnosing network problems does not really work like that. There is no tool you start and see "ah, that's it". To find the problem, first step is to identify the ISO/OSI-Layer and to rule out physical defects. After having ruled that out, in the majority of cases, it will be faulty or misconfigured software, mostly security software (AV scanners, software firewalls, hardware firewalls as well). Also quite often: old or faulty drivers.
Sure, I use ipconfig from time to time, and I am familiar with netsh, but I would never recommend to learn netsh for troubleshooting, it's simply too rare that it would amount to anything.
Author: JeffBeall replied at 2024-04-07 11:39:48
so i started playing with netmon, is this like wireshark?
Expert: Qlemo replied at 2024-04-07 11:07:31
It is always a good idea to have another tool able to show similar or same info. But netsh syntax is too complex to be able to remember the proper commands if you need them.
Well, the built-in tools should always work, else you are in trouble anyway.
Author: JeffBeall replied at 2024-04-07 11:02:53
ok, but that is kind of what i was looking for. because i learned that netsh wouldn't be a good tool, but for example, i haven't heard of ms netmon. so i could look at that.
i have used ipconfig a lot. but i like to have a few different tools. for example, if i have 3 tools, and for some reason, tool number 1 doesn't work, i can switch to tool number 2.
Expert: Qlemo replied at 2024-04-07 10:50:32
167 points EXCELLENT
Nope, netsh is no good for diagnostics or troubleshooting. Too many bugs, syntax changing with each OS, and such.
Network issues are so diverse it is impossible to name any tool being able to help in most of them. E.g. often you'll need a network capture - WireShark, MS NetMon or MS Message Analyzer are good stuff here, but you need to know "something" (in the sense of "second to all") about the networking protocols involved.
Of course you'll need IPConfig, route print in addition, but that is built-in.
Author: JeffBeall replied at 2024-04-07 10:39:43
"And could you write us what the networking problem you have now ?"
I'm not having problems. I just want to build an arsenal of tools when I do have problems.
so i was wondering if people have used the netsh command, and what they have found to be the most useful.
Expert: duncanb7 replied at 2024-04-07 10:29:54
take a look at this
http://technet.microsoft.com/en-us/library/cc725935(v=ws.10).aspx
Dunan
Dunan
