When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by leblanc
at 2024-04-05 08:36:38
Point:500 Replies:10 POST_ID:828908USER_ID:11810
Cascading Style Sheets (CSS);Hypertext Markup Language (HTML);Miscellaneous Web Development
Is there a tutorial on how to style the button like the pic below?
I did some research around and I don't see any tutorial where they have the buttons as a jpg file. Also, the button changes color based on the current page so you know where you are. Thx
Expert: duncanb7 replied at 2024-04-16 11:49:54
Thanks for your pt
Expert: Scott Fell (padas) replied at 2024-04-05 12:02:36
Link only answers deleted.
You can include links as support, but your answers should stand on their own. Additionally, you may not link to other Q/A sites. You can read our full policy in the help section. http://support.experts-exchange.com/customer/portal/articles/1162518
padas
Topic Advisor
padas
Topic Advisor
Expert: duncanb7 replied at 2024-04-05 11:00:38
125 points EXCELLENT
be reminded
set % or px in x or y that is different, just search background-position CSS in google
you will know more
you will know more
Expert: duncanb7 replied at 2024-04-05 10:58:14
http://w3schools.sins-realm.com/css/tryit.asp@filename=trycss_background-position_pixel.htm
you can set +ve or -ve in x or y position
Expert: duncanb7 replied at 2024-04-05 10:55:42
http://www.w3schools.com/cssref/pr_background-position.asp
you can set the image position in x% y%
Please be reminded ,just look at
your image /image/button.jgp on browser first and adjust its x y position
if that is okay, that is same as you can see in your menu
Author: leblanc replied at 2024-04-05 10:47:40
The buttons size does not display what I have (see below). My pic buttons are real size.
html:
<ul id="nav1"> <li><a href="index.html">Start / Images</a></li> <li class="cur"><strong>The HTML</strong></li> <li><a href="step2.html">The CSS</a></li> <li><a href="step3.html">The JavaScript</a></li> <li><a href="step4.html">That's all</a></li></ul> 1:2:3:4:5:6:7:
css:
#nav1{ clear:both; font-weight:bold; color:#666; margin-left:4px; float:left; list-style-type:none; background:url(images/blue_bar.jpg) no-repeat 8px 100% #fff; padding-bottom:10px;}#nav1 li{ list-style-type:none; float:left; margin:0 0 0 4px; padding:0 0 0 10px ; border-bottom:1px solid #999; background:url(images/button_down.jpg) #c0c0c0 top left no-repeat;}#nav1 li a{ color:#666; background:url(images/button_down.jpg) transparent top right no-repeat; display:block; padding:0 10px 0 0;}#nav li.cur,#nav li.over,#nav li:hover{ background:url(images/button_up.jpg) #3375b2 top left no-repeat; border-bottom:1px solid #036;}#nav li strong,ul#nav li.cur a,ul#nav li.over a,ul#nav li:hover a{ display:block; color:#fff; padding:0 10px 0 0; text-decoration:none; background:url(images/button_up.jpg) transparent top right no-repeat;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:
Expert: duncanb7 replied at 2024-04-05 10:18:38
You can test it whether you can get exact image path, for example
on Browser like FF or chrome, type
http://mysite.com/public_html/image/button.jpg
If you see the image on your browser that mean the path is correct
just put it the css file
if have time, know more about meaning of short path writing , for example
../image/button.jpg
/image/button.jpg
./imaage/button.jpg
../../image/button.jpg
../image/button.jpg
/image/button.jpg
./imaage/button.jpg
Expert: duncanb7 replied at 2024-04-05 10:14:12
background:url(navshadow.gif) no-repeat 8px 100% #fff;
just put correct or full path location of image . for example,
/home/youlogin/public_html/image/yourbutton.jpg if you don't
short path writing on javascript
OR write more your question in detail
Author: leblanc replied at 2024-04-05 10:07:50
I have the tab images and I want to use them for my navigation. I think the tutorial 8 from Duncan link is that I am looking for. But I cannot make it work properly with my buttons for some reason.
Expert: duncanb7 replied at 2024-04-05 08:48:00
Please take a look at item 05 and 06 of 30 in following link and click "tutorial link" for the detail under each item.
http://www.instantshift.com/2009/01/11/30-excellent-css-based-navigation-and-buttons-tutorial/
Hope understand your question completely.If not , please pt it out
