When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-19 02:19:38
Point:500 Replies:9 POST_ID:828896USER_ID:11059
Components;Computer Servers;Miscellaneous Hardware
Recently I have found out one hosting company offering 8000M CPU VPS server
and so I wonder why there is existing 8G CPU ?
As I remember from max Intel process speed is range from 3.3 to 3.7G today.
So my question is coming out for CPU speed
On general intel 3.7GHZ computer mother board, one socket L can allow only one CPU chip mount on and for example, one CPU chip could have 4 core or 8 core but
the overall computer CPU speed is still 3.7GZHZ regardless of how many core is in one
CPU chip.
Question-1:
My first question is what I say above is correct or not ( if we don't consider CPU
bus speed such as 1333MHZ) ? The number of CPU core in one CPU chip is
for allowing how many process or thread is running , for example, 16 thread for 4 core
which mean 16*4 process or thread running at the same time or max multi-tasking in one CPU chip with the same speed of 3.7G HZ, Right ?
Question-2:
Sometimes, I have seen there are two socket L on one mother board. Why is it ?
Whether the additional socket L will allow increase the overall computer CPU speed by 2* socket CPU speed =2*3.7GHZ=7.4GHZ which is closer to the hosting company offer
8GHZ CPU VPS server ?
What is different for overall computer CPU speed calculation from no of CPU socket and CPU cores consideration ?
Question-3: Some intel CPU device spec has thread feature such 16 or 8 threads. Is that for server CPU to handle how many process or thread at the same time in one core of CPU ?
Laptop/Personal computer is seldom to use thread feature intel CPU , Right ?
CPU chip.
Question-1:
Question-2:
Author: duncanb7 replied at 2024-03-20 02:12:29
Thanks for your reply and answer the question in detail
Expert: andyalder replied at 2024-03-20 02:04:07
125 points EXCELLENT
Yes, that's all correct.
Author: duncanb7 replied at 2024-03-19 19:55:33
in other words,
From your ink provide, I conclude this
1- core and socket is same purpose idea to increase CPU efficiency to handle
multi-tasking process but more socket on mother board will increase hardware cost
and power consumption than more core inside of one CPU Chip package. And core arch is better socket architecture in term of high CPU operation efficiency and low power dissipation
2-Total thread in the intel Xeon spec in above link is 8 thread with 4 cores that means one core handle 2 thread if hyper-thread is enable , otherwise, just handle only 1 to 1.
3-There is NO actual single 8000MHZ CPU, the hosting advertising just promote its service or its server 's CPU speed can handle processs or job similar to 8000MHZ CPU
that may be actually just consisted of one single socket CPU chip at 1000Mhz with 8 core with 8 thread or 2000MHZ with 4 core and 4 threads
Is it correct to what I understand ? Please advise
Author: duncanb7 replied at 2024-03-19 13:04:39
since you said a lot of slice, hyper, I need sometime to absorb and understand it and its meaning, thanks for your reply, and talk you tomorrow
Expert: andyalder replied at 2024-03-19 12:57:45
Each core can handle 1 thread or if hyper-threading is enabled then 2 threads. That particular chip has 4 cores which can handle 8 threads between them if hyper-threading is enabled.
Cores are individual CPUs (or at least the main part of the CPU) built on the same slice of silicon. If you look at the photo of the "Barcelona" cpu at http://en.wikipedia.org/wiki/Opteron you can see that there are 4 identical circuits on it - one in each quadrant. In that photo the processing part of the cores is mainly pink, the bits that like symmetrical rectangles are cache ram.
Author: duncanb7 replied at 2024-03-19 12:40:59
http://ark.intel.com/products/39718/Intel-Xeon-Processor-W3520-8M-Cache-2_66-ghz-4_80-gts-Intel-qpi
From your reply, what is actual meaning of core and thread and its different to each other.
Please read the link attached
I thought one single intel Chip package can have 2/4/8 CPU inside as 2/4/8 cores and each core in one Chip can handle 4/8/16 thread or process respectively simultaneously . Is it right ? OR number of core in one CPU chip mean just thread or process handle in one single CPU chip (there is NO 2/4/8 physical CPU inside) and not actual
hardware or semiconductor stuff. So number of core in CPU is not real just CPU
management or software method to handle process.
4 core CPU doesn't mean we have 4 single 3.7 GHZ CPU inside of one Single intel CPU chip
package. Right ?
And why sometimes, we can see two socket L on one mother board ? Is it for increasing
to CPU speed if user is willing to buy one more CPU chip .
So the question is around, number of core , thread with one single CPU chip
and number of socket on mother board
package. Right ?
Expert: andyalder replied at 2024-03-19 12:22:06
Presumably it's this that you are looking at - http://www.hosting24.com/servers.php
I have no idea what they mean, you would have to ask them via live chat but I suspect you just get 8 threads that may possibly run at 1Ghz each guessing from how the slider works, or maybe you get 8 1Ghz virtual machines. It's really a marketing thing.
You're not going to get all 8 1Ghz threads 24x7 anyway, since you would run out of bandwidth unless you just used it to calculate the value of Pi or tried to mine bitcoins with it.
As far as your questions go...
1. The number of cores is indeed the number of threads you can run simultaneously, although with hyperthreading you can run twice that since each core acts like two virtual cores. Note the word simultaneously, you will see a lot more than 16 processes running on your home PC but most of them are hanging about in RAM waiting for the scheduler to give them a go on the CPU. That will be the case with your VPS server too, they're not going to dedicate all that performance to you, it's time-sliced so your virtual machine only gets a small fraction of the CPU time.
2. The more CPUs there are on the board the more simultaneous threads you can run, it doesn't scale quite linearly, after adding 4 CPUs you can still run 4 times as many threads at once as you could on a single CPU but there's contention for RAM bandwidth etc so it's not quite 4 times as fast. If you have a single-threaded application then 100 cores won't be any faster than 1 core since 99 of them would be idle.
3. Intel will list the number of threads as twice the number of cores if hyper-threading is available to make two virtual cores out of each physical core. Hyperthreading doesn't necessarily speed things up since the two virtual cores share one arithmetic logic unit. Top end Intel based laptops and PCs often have hyper-threading available but not so oftn on the cheaper ones.
Author: duncanb7 replied at 2024-03-19 11:48:00
Selected Package:CPU Speed: 8000 MhzMemory: 8192 MBDisk Space: 80000 MBBandwidth: 8000 GBConnection: 100 Mb/sDedicated IP's 8 IP'sPrice: $118.72/mo 1:2:3:4:5:6:7:8:9:10:11:
From attached ad, you will see 8000M CPU speed, so I wonder CPU can
have such speed.
If possible, could you review my those three question
Expert: andyalder replied at 2024-03-19 09:57:54
There is indeed no 8Ghz CPU although it's just possible to overclock them to that with rediculously expensive cooling. They're probably multiplying the clock speed by the number of cores but even that isn't really valid since you only get a slice of the host. Where did you see the advert - URL.
