When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-10 09:05:48
Point:500 Replies:5 POST_ID:828893USER_ID:11059
Windows 7;Windows Batch Scripting;Shell Scripting
Dear Expert,
I've one file called "junk.txt" in which I would like to replace Hostname and PortNumber
string with new value using window batch shell script , but I am spending more a few
hour in google, and still can not solve why I can not echo str variabie which
is always empty from following script code, Could you help on this, how to find
a string in string and replace with the new value. And the string addtion is "+" psosible ?
set newip="203.1.123.342"
set newport="00001779"
for /F "tokens=*" %%i in (junk.txt) do set str=%%i & echo %str% & if (%str:~1,9)=="HostName") str='"HostName"="'+'"+newip+'""
junk.txt file
junk.txt file
"Present"=dword:00000001"HostName"="217.76.12.127""Protocol"="ssh""PortNumber"=dword:00001771"CloseOnExit"=dword:00000001 1:2:3:4:5:
Expert: dragon-it replied at 2024-03-10 10:43:29
Ok, no problem. Worked for me here but then copy/pasted wrong version, line 19 should have been
echo %%i=!value!
Steve
echo %%i=!value!
Steve
Author: duncanb7 replied at 2024-03-10 10:01:14
Thanks for all of your rely.
I tried obda 's code in one time, it works as I expect
and dragon-it, thanks for your code, I tried it that seems not working
even review it many times and check all correct file typing and path.
The output junk.txt is same as before
Thanks for your attached link for the subject
Have a nice
Have a nice
Expert: dragon-it replied at 2024-03-10 09:29:28
I read there that you wanted "+" in the results, if not just remove the "+" characters.
Steve
Steve
Expert: dragon-it replied at 2024-03-10 09:28:25
100 points EXCELLENT
Try this. Few problems in there including within a single command like the for command you can't access variables set like your str entry unless you have delayedexpansion turned on (see line 2). Then you use !variable! to access.
Steve
Steve
@echo offsetlocal enabledelayedexpansionset newip=203.1.123.342set newport=00001779cd /d c:somedirwithitinREM Delete previous go if needed and rename file to junk.old to processdel junk.old 2>NULrename junk.txt junk.oldREM Make backup copy of filecopy /y junk.old junk.bak(for /F "tokens=1,2 delims==" %%i in (junk.old) do ( set value=%%~j if /i "%%~i"=="HostName" set value="+%newip%+" if /i "%%~i"=="PortNumber" set value="%newport%" echo %%i=%%j)) > junk.txtREM Remove this if wantedtype junk.txtpause 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:
Other alternatives are to use a util. to do it for you, e.g.
http://www.paulslore.com/utils/chgstr.zip
http://tools.tortoisesvn.net/grepWin
http://www.programmersheaven.com/download/41236/download.aspx
http://software.reinhardt.nu/ssr/index.htm
http://fart-it.sourceforge.net/
http://www.gnu.org/software/sed/
http://www.inforapid.de/html/searchreplace.htm
http://www.nodesoft.com/SearchAndReplace/Default.aspx
http://www.no-nonsense-software.com/freeware/
http://www.bestcode.com/html/findreplace.html
Expert: oBdA replied at 2024-03-10 09:28:01
400 points EXCELLENT
Try it with this script; it will make a backup of the original file before changing the original:
@echo offsetlocal enabledelayedexpansionset InputFile=C:Tempjunk.txtset NewHostName=203.1.123.342set NewPort=00001779set BackupFile=%InputFile%.bakif not exist "%BackupFile%" copy "%InputFile%" "%BackupFile%" >NULif exist "%InputFile%" del "%InputFile%"for /f "tokens=1-3 delims==:" %%a in ('type "%BackupFile%"') do ( if "%%~c"=="" (set Line=%%a=%%b) else (set Line=%%a=%%b:%%c) if "%%~a"=="HostName" (set Line=%%a="%NewHostName%") if "%%~a"=="PortNumber" (set Line=%%a=%%b:%NewPort%) echo !Line! >>"%InputFile%" echo !Line!) 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
