When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-02-27 01:45:45
Point:500 Replies:7 POST_ID:828889USER_ID:11059
Windows 7;Hypertext Transfer Protocol (HTTP);Networking Protocols
Question-1
I restart my Window 7 computer , and type command netstat -a -n -o
to display all network port but I could NOT find any port about 80 (http port)
Why ? and I go to try my other XP computer, it shows the 0.0.0 0:80 on
Local Address from netstat -a -n -o command output.
Question-2
When I open chrome browser on my window 7 computer, and
go to check netstat -a -n -o command, and find the following output
Yes, of course since issue on question-1, I could NOT find any port of 80
But I think about how can I go to google.com default page on my chrome
browser without port 80 listen? And I check the following output, I found
something like
TCP 219.77.4.127:49708 74.125.128.120:443 ESTABLISHED 448
The 219.77.4.127 is my ISP address after check ipconfig command and 74.125.128.120:443 is google.com 's https site.
Why the port for http on my local address is 49708 instead of 80 ?
Or some hidden software installed on my computer to switch port 80 to 49708
such as http proxy ? But I never use any http proxy on my this window 7 computer .
Question-2
something like
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING 900 TCP 0.0.0.0:445 0.0.0.0:0 LISTENING 4 TCP 0.0.0.0:554 0.0.0.0:0 LISTENING 1032 TCP 0.0.0.0:2869 0.0.0.0:0 LISTENING 4 TCP 0.0.0.0:10243 0.0.0.0:0 LISTENING 4 TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING 580 TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING 964 TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING 500 TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING 628 TCP 0.0.0.0:49156 0.0.0.0:0 LISTENING 652 TCP 127.0.0.1:2869 127.0.0.1:49703 TIME_WAIT 0 TCP 127.0.0.1:2869 127.0.0.1:49704 ESTABLISHED 4 TCP 127.0.0.1:5354 0.0.0.0:0 LISTENING 1620 TCP 127.0.0.1:49157 0.0.0.0:0 LISTENING 1928 TCP 127.0.0.1:49169 0.0.0.0:0 LISTENING 984 TCP 127.0.0.1:49704 127.0.0.1:2869 ESTABLISHED 1032 TCP 169.254.202.6:139 0.0.0.0:0 LISTENING 4 TCP 219.77.4.127:49706 173.194.127.244:443 TIME_WAIT 0 TCP 219.77.4.127:49708 74.125.128.120:443 ESTABLISHED 448 TCP 219.77.4.127:49709 74.125.128.120:443 ESTABLISHED 448 TCP 219.77.4.127:49710 74.125.128.94:443 ESTABLISHED 448 TCP [::]:135 [::]:0 LISTENING 900 TCP [::]:445 [::]:0 LISTENING 4 TCP [::]:554 [::]:0 LISTENING 1032 TCP [::]:2869 [::]:0 LISTENING 4 TCP [::]:10243 [::]:0 LISTENING 4 TCP [::]:49152 [::]:0 LISTENING 580 TCP [::]:49153 [::]:0 LISTENING 964 TCP [::]:49154 [::]:0 LISTENING 500 TCP [::]:49155 [::]:0 LISTENING 628 TCP [::]:49156 [::]:0 LISTENING 652 TCP [::1]:49158 [::]:0 LISTENING 1928 UDP 0.0.0.0:500 *:* 500 UDP 0.0.0.0:4500 *:* 500 UDP 0.0.0.0:5004 *:* 1032 UDP 0.0.0.0:5005 *:* 1032 UDP 0.0.0.0:5355 *:* 1228 UDP 0.0.0.0:62511 *:* 1620 UDP 127.0.0.1:1900 *:* 4652 UDP 127.0.0.1:56461 *:* 3644 UDP 127.0.0.1:59562 *:* 4652 UDP 169.254.202.6:137 *:* 4 UDP 169.254.202.6:138 *:* 4 UDP 169.254.202.6:1900 *:* 4652 UDP 169.254.202.6:5353 *:* 1620 UDP 169.254.202.6:59561 *:* 4652 UDP 219.77.4.127:1900 *:* 4652 UDP 219.77.4.127:59560 *:* 4652 UDP [::]:500 *:* 500 UDP [::]:4500 *:* 500 UDP [::]:5004 *:* 1032 UDP [::]:5005 *:* 1032 UDP [::]:5355 *:* 1228 UDP [::]:62512 *:* 1620 UDP [::1]:1900 *:* 4652 UDP [::1]:59559 *:* 4652 UDP [fe80::94a8:db5:2904:ca06%12]:1900 *:* 4652 UDP [fe80::94a8:db5:2904:ca06%12]:5353 *:* 1620 UDP [fe80::94a8:db5:2904:ca06%12]:59558 *:* 4652 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:
Author: duncanb7 replied at 2024-02-27 03:01:43
Totally agree your comment. Thanks for your reply,
For my memo only:
-the issue in this thread is NOT related to Window 7 & or XP system
-Why my linux server can handle many http accesses with just only TCP/IP http port 80,
that is because apache linux server is multi-process that
mentioned on this link , http://en.wikipedia.org/wiki/Apache_HTTP_Server
For my memo only:
Author: duncanb7 replied at 2024-02-27 03:00:35
Now better understand after your comment and I can verfiy it from that
I go to check the client and server communication port on $_SERVER variable from
php code between my linux server and my window 7 computer
The php code report $_SERVER['REMOTE_PORT'] and $_SERVER['REMOTE_ADDR'] that is
matched to netstat command output on my window 7 computer.
In other words, when I try http://mylinuxsite.com/server.php on chrome browser , it will
go to my server port 80 since http or no http typing will be interpreted as access server TCP/IP port 80 on browser and https for 443.
The connection is between server 80 port and my computer dynamic port when
typing http on browser.
Why it use dynamic TCP port for browser that is I believe because it can use it for multi-thread tasking process so that we can create many instances or type browsers http accesses at the same time wihtout waiting
Expert: Miftaul replied at 2024-02-27 02:39:10
Google chrome browser uses your local dynamic port to establish a TCP session with google.com.
TCP session is established between your local port and the remote server port. Here the local port will be Dynamic Ports (49152-65535) and the remote server port is 80 for http webpages and 443 for https.
The remote server ports are actually well known port (0 - 1023), it the service that you are accessing will determine which remote port the session needs to be established.
Author: duncanb7 replied at 2024-02-27 02:24:58
So you mean google chrome browser don't use port 80, Right ?
And why chrome browser USE dynamic ports instead of static port ?
Expert: Miftaul replied at 2024-02-27 02:18:08
Yes, your computers dynamic port will establish a TCP session with the web-servers well known port (0-1023).
Port 80 is registered for http service and 443 for https. The device that providing these services will open these ports. and the host computers accessing the services will have their dynamic ports open.
Here is the list of ports - Link
Author: duncanb7 replied at 2024-02-27 02:06:41
In other words, google chrome browser will open TCP session to use dynamic port instead of 80. So the http TCP/IP is not just working on http port 80 only but also other port
such as 49000 to 66500. Right ? Why he is doing that way for dynamic port, for security ?
Expert: Miftaul replied at 2024-02-27 01:57:36
When we are opening www.google.com your computer opens a TCP session on its local dynamic port with the web servers port 80 ()for http) and 443(for https).
The only time you might see port 80 open on your local computer is when your computer is providing some sort of http services.
