When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by mike99c
at 2024-02-17 06:47:17
Point:500 Replies:3 POST_ID:828887USER_ID:10
jQuery;;Web Browsers
I would like to know the best way to detect if a browser is specifically Safari using jQuery.
I am aware that webkit is shared by Chrome and Safari but I am specifically interested to know if the browser is Safari and nothing else.
Expert: duncanb7 replied at 2024-02-17 08:31:17
Thanks for your pt, there is a lot of solution in google search
for Jquery browser detection but that might NOT be
consistent and that some is depended on the jquery plugin version.
You can simplify those javascript code for your need that is not depend on
javascript version
javascript version
Expert: duncanb7 replied at 2024-02-17 08:06:51
Dear mike99c,
You can use the following javascript code to test Safari browser or not
I put the document.write in if statement for Safari browser detection only
and display it into body tag.
And if it is not Safari browser, it will keep the message of "It is NOT Safari Browser" in body tag.
The document.write you can put in other if statement for other browser you want to test
Hope I understand your question completely, if not please pt it out,
The code is Not fully tested
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "/WEB/INF/xhtml1-strict.dtd"> <html> <head> <meta http-equiv="CONTENT-TYPE" content="text/html; charset=UTF-8"/> <meta http-equiv="CACHE-CONTROL" content="NO-STORE"/> <meta http-equiv="EXPIRES" content="-1"/> <title>Safari Browser Test</title> <script type="text/javascript"> function init(){var nVer = navigator.appVersion;var nAgt = navigator.userAgent;var browserName = navigator.appName;var fullVersion = ''+parseFloat(navigator.appVersion);var majorVersion = parseInt(navigator.appVersion,10);var nameOffset,verOffset,ix;// In Opera, the true version is after "Opera" or after "Version"if ((verOffset=nAgt.indexOf("Opera"))!=-1) { browserName = "Opera"; fullVersion = nAgt.substring(verOffset+6); if ((verOffset=nAgt.indexOf("Version"))!=-1) fullVersion = nAgt.substring(verOffset+8);}// In MSIE, the true version is after "MSIE" in userAgentelse if ((verOffset=nAgt.indexOf("MSIE"))!=-1) { browserName = "Microsoft Internet Explorer"; fullVersion = nAgt.substring(verOffset+5);}// In Chrome, the true version is after "Chrome"else if ((verOffset=nAgt.indexOf("Chrome"))!=-1) { browserName = "Chrome"; fullVersion = nAgt.substring(verOffset+7);}// In Safari, the true version is after "Safari" or after "Version"else if ((verOffset=nAgt.indexOf("Safari"))!=-1) { browserName = "Safari"; fullVersion = nAgt.substring(verOffset+7); if ((verOffset=nAgt.indexOf("Version"))!=-1) fullVersion = nAgt.substring(verOffset+8); txt ="<p id='pd0' style='color:blue'> It is Safarai Browser, Browser name ="+browserName+'</p>'; document.write(txt);}}</script></head><body onload="init();">It is NOT Safari Browser</body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:
Expert: leakim971 replied at 2024-02-17 07:05:41
var isSafari = navigator.vendor.indexOf("Apple")==0 && /sSafari//.test(navigator.userAgent); // true or false 1:
