When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by tankergoblin
at 2024-01-12 04:36:46
Point:200 Replies:15 POST_ID:828881USER_ID:11786
Linux;;
how to enable telnet in red hat 4 enterprise
Author: tankergoblin replied at 2024-01-20 02:16:08
mistake
Expert: serialband replied at 2024-01-14 12:29:07
22 points GOOD
Since everyone is suggesting putty and from the tone of all the responses, I assume you're on a Windows system trying to log in to a linux box.
If you're unfamiliar with the command line, you could download and install WinSCP to drag and drop files. Set up the connection the same way as you would with putty. Sometimes using WinSCP is easier for quick one off copies or multiple selected folder copies
Expert: Tintin replied at 2024-01-12 23:03:15
22 points GOOD
Have to say that if you already have ssh configured, not sure why you'd want to use an insecure protocol like telnet.
Expert: duncanb7 replied at 2024-01-12 21:07:15
22 points GOOD
so you had better to log into SSH shell with the port 22 If port 22 is not working, go to
ask your hosting company for exact port number . After log-in SSh shell, execute those
command to install telnet , all is done.
Why you need to use telnet ? there is pcsp.exe for file transfer at
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Expert: Tintin replied at 2024-01-12 13:28:06
22 points GOOD
port 22 is the default port for ssh. port 23 is the default port for telnet.
Author: tankergoblin replied at 2024-01-12 08:42:34
port 22 is ssh ??
Expert: duncanb7 replied at 2024-01-12 06:50:33
22 points GOOD
On putty program , type your host IP , yyy.y.yyy.yy and Port 22( and check your hosting company what is port if not 22 and check your IP from them) ,after open command, it will open new promote shell, and then type your login and password, and then you will log into shell, and then type
those commands in prev post for telnet
Author: tankergoblin replied at 2024-01-12 06:37:45
yah i know this link and already have putty but how to login shell using putty.. any site discuss on this?
Expert: duncanb7 replied at 2024-01-12 06:36:03
22 points GOOD
it is not silly, just a question,
Download it
if your need is not urgent, just type putty in search enginer
and study other thing you need , take a chance to know more
Download it
Author: tankergoblin replied at 2024-01-12 06:28:20
ok sorry if this question is silly but how to login shell using putty?
Expert: duncanb7 replied at 2024-01-12 06:00:39
22 points GOOD
I think you had better to log into linux shell
As I remember there is only a few linux command could run with putty
Why not log into the shell and do it easily ?
Author: tankergoblin replied at 2024-01-12 05:36:58
can i type those commond with login to ssh and login with my username and password then type those command
Expert: duncanb7 replied at 2024-01-12 05:06:21
23 points GOOD
yes,log into your linux shell from putty (if your linux is at remote site) and type those command
Author: tankergoblin replied at 2024-01-12 05:01:33
above step all use command line and all need to be done?
Expert: duncanb7 replied at 2024-01-12 04:42:22
23 points GOOD
Did you try the following command
-1 yum install telnet-server telnet
-2 vi /etc/xinetd.d/telnet
Make sure that disable = yes is changed to read disable = no.
-3 chkconfig telnet on
-4 chkconfig xinetd on
-5 service xinetd restart
