When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-01-11 04:08:09
Point:500 Replies:4 POST_ID:828879USER_ID:11059
jQuery;;JavaScript
There're two forms without any id attribute help that I want to.
I want to get html() for all class name ='mesg' in first form only when first form is
onsubmit . I try the following chkvalid() code, but it shows all classname="mesg" even
including second form. the output is "0:A","1:B","2:C","3:D" from console.log
I just want "0:A", "1:B" within first form only .
function chkvalid( obj) {
$( ".mesg" ).each(function( index ) {
console.log( index + ": " + $( this ).html() ); });
So now I try to fix the issue from getting the correct jquery selector such as
$(obj).$(".mesg").each(function( index ) {
but it fail since it is not allowed to use $(obj) and then point to other object inside of
parent object.
How to do that ? and please don't ask me to add id attribute in each form to distinguish both forms.
parent object.
<htm><body><form onsubmit="chkvalid(this);return false;"><table><tr><td class='mesg'>A</td></tr><tr><td class='mesg'>B</td></tr><tr><td><button type='submit'><span>Submit</span></button></td></tr></table></form><form onsubmit="chkvalid(this);return false;"><table><tr><td class='mesg'>C</td></tr><tr><td class='mesg'>D</td></tr><tr><td><button type='submit'><span>Submit</span></button></td></tr></table></form></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:
Author: duncanb7 replied at 2024-01-11 07:06:10
Thanks for your reply
have a nice day
have a nice day
Expert: leakim971 replied at 2024-01-11 06:44:23
Question-1:
Why did you add << return false >> here :
I see no "CONDITIONAL" logic to submit OR NOT the form as it always do << return false >>
Q2 : this represent a context, you can use $(this).find(".mesg") instead
$(this, ".mesg") represent all the form inside an element with mesg class, non-sense
Q3 :
why not but as jQuery slogan is write less do more...
$(".mesg", this)
vs :
16 vs 21 characters
Q3 :
$(".mesg", this)
vs :
16 vs 21 characters
Author: duncanb7 replied at 2024-01-11 06:36:49
Thanks for your reply, leakim971
Question-1:
Why I need this to prevent return false ?
event.preventDefault(); // prevent submission of the form like << return false; >>
onsubmit(chkvalid();return false); where "return false" by that I can do submit form
on form action after doing chkvalid javascript function
Question-2
What is meaning of $(".mesg",this), where this I understand that is refered to the submit object, but what is sequence meaning of $(".mesg", this) ? and why not $(this,".mesg") ?
Question-3
$(obj ).find(".mesg").each(function( index) {
I used $(obj). find() to get it work finally , is it same as your method of $(".mesg",this) ?
I will try your code since I feel find() is not good since it will do some loop seach and
it might not need it since each() will handle this. So the question is finding a good selector , Right ?
Question-1:
Question-2
Question-3
Expert: leakim971 replied at 2024-01-11 05:49:34
In your code :
Use : $( ".mesg", obj ).each(function( index ) {
instead : $( ".mesg" ).each(function( index ) {
Test page : http://jsfiddle.net/UPNLv/
<html><head><script src="//ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.min.js"></script><script> jQuery(function($) { $("form").submit(function(event) { event.preventDefault(); // prevent submission of the form like << return false; >> $( ".mesg", this ).each(function( index ) { console.log( index + ": " + $( this ).html() ); }); }); });</script></head><body><form><table><tr><td class='mesg'>A</td></tr><tr><td class='mesg'>B</td></tr><tr><td><button type='submit'><span>Submit</span></button></td></tr></table></form><form><table><tr><td class='mesg'>C</td></tr><tr><td class='mesg'>D</td></tr><tr><td><button type='submit'><span>Submit</span></button></td></tr></table></form></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:
