When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-01-07 02:19:32
Point:500 Replies:3 POST_ID:828874USER_ID:11059
Web Browsers;Hypertext Markup Language (HTML);Cascading Style Sheets (CSS)
I used javascript to extract my user-agent as follows
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/31.0.1650.63 Safari/537.36
and then I go some user-agent extration website to report the following information
in the code area. After reading the website of
http://webaim.org/blog/user-agent-string-history/ about history of user-agent string,
now know more about user-agent.
My question is
Question-1:
KDE (http://www.kde.org/) is first company or org doing HTML layout compiler for browser,right ? Could you talk more about "(KHTML, like Gecko)"
Question-2:
Webkit (http://www.webkit.org/), what they are doing for browser, could you talk more
about AppleWebKit/537.36. And we always use css such as background: -webkit-gradient(linear, left top, left bottom, color-stop(0%, #6495ed), color-stop(100%, #ffffff));
Is that constructed by such Webkit org or company, right ?
My question is
Question-1:
Question-2:
Mozilla/5.0 They claim that it is based on Mozilla user agent (only true for Gecko browsers). It is now used only for historical reasons.Windows NT 6.1 OS signatureWOW64 Windows running on a 64-bit processor signatureAppleWebKit/537.36 Open source application framework ver. 537.36(KHTML, like Gecko) HTML layout engine developed by the KDE projectChrome/31.0.1650.63 browser signatureSafari/537.36 browser signature 1:2:3:4:5:6:7:
Author: duncanb7 replied at 2024-01-12 00:52:43
Thanks for all of your reply
Expert: Kravimir replied at 2024-01-07 16:23:53
Yes, KDE was the first organization to write code specifically for that web browser. Then Apple started working on it and then it was made an open source project under the name Webkit to which Google also has made significant contributions.
"Gecko" refers to the rendering engine by Mozilla, which is used in many browsers, most notably of which is Firefox. The phrases "Mozilla/5.0" and "like Gecko" are both used so old and very poorly written browser sniffers which only recognize Internet Explorer and Mozilla browsers will treat Webkit browsers as they would true Mozilla browsers. (I should mention that browser sniffing is a practice that should be avoided as much as possible.)
"-webkit-gradient()" is a CSS3 prefixed value. To speed up the creation of new CSS standards, browser vendors each have a vendor prefix for use when implementing experimental features (some being much more experimental than others) before the the draft of whichever CSS3 module they belong to is completed. Vendor prefixes include "-webkit-", "-khtml-", "-moz-" for Mozilla, "-ms-" for Microsoft, and "-o-" for Opera.
@Dave, I expect Duncan means "rendering engine", not "compiler".
Expert: Dave Baldwin replied at 2024-01-07 15:54:24
KDE is a desktop GUI for Linux with a lot of utility programs. I've never heard of an HTML compiler from them. The only HTML compiler I know of is the Help Compiler for Windows. In addition, browsers need to get an un-compiled plain text version of a web page.
Gecko is the Mozilla page rendering 'engine' for Firefox, SeaMonkey, and other Mozilla browsers.
Webkit is a rendering engine like Gecko is and this page http://www.webkit.org/ says that it was derived from KDE. Webkit is also used by Apple products and Google Chrome. When you see something that starts with "-webkit-" the designer is trying to use a non-standard feature of the Webkit rendering engine. Mozilla features start with "-moz".
And there are thousands of User Agent Strings. http://www.useragentstring.com/pages/useragentstring.php
