When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-12-21 13:30:42
Point:500 Replies:4 POST_ID:828867USER_ID:11059
Android;iPhone;Mobile Web
my samsung android phone is 480*854 resolution after reporting from javascript code as follows
window.screen.availWidth;
window.screen.availHeight;
window.devicePixelRatio;
Question-1
The device pixel ratio is 1.5 , So it should be reported in unit of point (pt) for those width and height, right ? And what is the best way to detect the phone device resolution ?
So I try to test it and put the background image well fit into the body of html5 page
using css with background-size:720pt 1281pt ; (i.e 480*1.5pt 854*1.5pt) But it just almost close to fit to the whole body becoz the width of display image is not like 480*1.5pt , it seems like the width is 440*1.5pt and the image height is well fitted .So I believe what I wrote above might be something wrong, Please point it out if so,
Question-1
Author: duncanb7 replied at 2024-12-23 11:10:11
thanks for all of your reply.
I am using javascript and detect window.screen.availWidth , window.screen.availHeight
& devicePixelratio to do css for all devices that will be more accurate
Expert: chilternPC replied at 2024-12-21 15:26:31
100 points GOOD
use the media query to load the specific css (this way you don't download extra data on a mobile)
i.e.
// common css here....
<link rel..... style.css/>
//laptop one here...
@media screen and (max-width:1300px)
<link rel.....href="laptop.css>//
// tablet here ..
@media screen and (max-width:690px)
<link rel.....href="tabletportrait.css>//
// /smartphone here ..
@media screen and (max-width:400px)
<link rel="stylesheet" media="(max-width: 800px)" href="example.css" />//
i.e.
// tablet here ..
Author: duncanb7 replied at 2024-12-21 14:20:23
So the link tag just work on phone device only with its width less than 880px, Right ?
How to let NOT to read other normal css file on phone device ?
for example,
<link rel.....href="file.css> // that is target to work only on laptop computer.
<link rel.....href="file2.css>// that is target to work only on laptop computer.
<link rel="stylesheet" media="(max-width: 800px)" href="example.css" />//that is only work for phone device
for example,
Expert: Scott Fell (padas) replied at 2024-12-21 13:56:56
400 points GOOD
First, your images should be in px and not pt (Pixels vs Points). Points is a measurement for printing not display.
You would simply want to use a media query to detect the size of the viewport and display the appropriate image. https://developer.mozilla.org/en-US/docs/Web/Guide/CSS/Media_queries
@media (max-width: 300px) { img.small{display:inline;} img.large{display:none;} }@media (min-width: 301px) { img.small{display:none;} img.large{display:inline;} } 1:2:3:4:5:6:7:8:
<div class="main_image"><img class="small" src="myimage_small.jpg"><img class="large" src="myimage_large.jpg"></div> 1:2:3:4:
