When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-12-17 05:48:30
Point:500 Replies:7 POST_ID:828864USER_ID:11059
Secure Socket Layer (SSL) & HTTPS;Linux;Apache Web Server
When I access my https site with my self-cert SSL, the browser will give me red-cross and slash-mark on my browser address bar around https, why does it happen ? Whether do I have to or must buy trusted SSL cert instead of self-cert to disable the red cross-mark or slash-mark on https ?
For buying trusted SSL certificate, I have search all of it. there is really expensive or low-cost one ,for example some offer $600US/year and some offer $5US/year, why it is so much different in pricing if those company just use similar encrypt algorithm ?
I also find some Ad about some large hosting company provide Turbo SSL cert through Domain Control validation to cut down the certificate cost. What is it about ?
Author: duncanb7 replied at 2024-12-18 08:46:30
Thanks for all of your reply
Expert: tsaico replied at 2024-12-18 08:19:02
166 points EXCELLENT
To tell you the truth, I would just buy the basic GoDaddy SSL. It gets rid of any weird red bars, doesn't require any imports for end users (and no one will import it, end users are notoriously lazy) and it also keeps you from having to write a ton of "how to" for every mobile device (iOS, Droid, Windows) and browser (IE 8-11, Opera, Firefox, Safari, Chrome). I can guarantee the time you spend in making them all with screen shots, you could have paid for the $70 for an actual SSL and saved everyone the headache.
Expert: Felix Leven replied at 2024-12-18 04:41:48
StartSSL™ Free supports:
Web server certificates (SSL/TLS)
Client and mail certificates (S/MIME)
128/256-bit encryption
US $ 10,000 insurance guaranteed
Valid 1 year (365 days)
Author: duncanb7 replied at 2024-12-18 03:54:48
startssl mentioned the free SSL cert only encrypt to login name and email address only
that might be explained why it is free
Expert: Felix Leven replied at 2024-12-18 03:47:12
167 points EXCELLENT
For my testing Server/Networks (win only) I startet to use startssl certs, because it is free or very cheap. Even some verdors like Citrix want to force you into more expensive solutions.
Author: duncanb7 replied at 2024-12-17 15:05:42
tsaico. thanks for your good post,
Do you agree self-sign cert can be used as a trusted cert if users/visiotrs are willing to import and save the my site self-sign cert into their browser trusted vendor folder after clicking browser options setting that will get rid of or delete the red-cross and red slash mark nearby https on address bar ?
Expert: tsaico replied at 2024-12-17 13:20:22
The red bar is because while the traffic is under SSL, there is no 3rd party verifying your server is indeed your server. This can be a phishing attack that got someone to go to the wrong website and they inadvertently give out their login information or account information. Think of it like your state issues identification. Without it, it is just your word claiming you are actually you. In order to get an ID (your SSL), you have to go the government (3rd party, like GoDaddy) and get them to vouch for you by supplying their needed information. Then there are certain restrictions on who can print these IDs, so not everyone is allowed to just print them, or rather not all places accept any ID.
The red bar is just saying there is something that isn't right about it as a warning to the user. Having mismatched names, using a certificate for secure.site.com when it is actually othersite.here.com will produce the same results of a red bar.
As for the reason on the price differences, between companies, I have no idea to tell you the truth. I don't know why basic ssl from godaddy is $70/yr, but startssl.com gives it for free. As for why there are different levels of SSL, the amount of encryption goes up, the other features like making the address bar green vs letting it be white like normal, and being able to do either wildcard (meaning you can use the same SSL in any of your server names) or each one has several names on the same ssl are usually where the price comes up a little.
Domain Control is usually where they tell you to put a specific code string on the public website, so they can verify that you actually own it vs. sending an email for someone to click on and approve. This is usufull when the names on the email listed in the WHOIS database are either obscured (often sold as a "privacy feature") or just incorrect. If you can upload a file to the website, then that is proof enough that you are authorized to request the SSL on behalf of a domain.
