When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by hdw632
at 2024-12-01 18:16:47
Point:500 Replies:5 POST_ID:828862USER_ID:11774
WordPress;;Hypertext Markup Language (HTML)
On this page there is a LOT of space in the tables and in between tables. Anyone know what is causing this? I am using wordpress with the thesis framework. Thanks!
Author: hdw632 replied at 2024-12-01 19:40:26
Awesome, Thanks!
Expert: Jason C. Levine replied at 2024-12-01 18:41:45
A post with links proffered as answers without explanation or context has been deleted. Please repost if you can add information that explains what the links are and how the information will solve the problem.
Expert: Scott Fell (padas) replied at 2024-12-01 18:38:00
The spacing is not so bad except for the
Your h2 tags have the following css where you can take down the margin and line-hight. Just edit the css file.
.grt h2 {font-family: Arial, "Helvetica Neue", Helvetica, sans-serif;font-size: 18px;line-height: 32px;margin-top: 41px;margin-bottom: 14px;} 1:2:3:4:5:6:7:
While your at it, change the line height of the h1 tag because when, "2 WEEK ACCEL. BROKER COURSE" wraps it overlaps.
Lastly, I would change
to below by adding a margin-top so the columns are not butt up against the bottom of the paragraph above.
media="all".column {float: left;"margin-right: 5%;"width: 100%;"margin-top: 20px;"} 1:2:3:4:5:6:7:
Expert: duncanb7 replied at 2024-12-01 18:37:27
You mean you tried those method before and not working at all ?
Or I am not understanding your question ?
Author: hdw632 replied at 2024-12-01 18:34:50
That doesn't seem to have fixed the problem...
