When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by sirbounty
at 2024-11-30 17:24:36
Point:500 Replies:20 POST_ID:828854USER_ID:11720
Home Theater Systems;Personal Electronics;Components
Just got a blu ray with only an hdmi output and a digital audio output.
I got an hdmi to dvi cable/adapter to connect it to my tv, but nothing I've tried produces any audio. Any ideas what I can do to get this working?
Author: sirbounty replied at 2024-12-04 10:54:38
I just grabbed the first one...really hoping to replace this tv soon anyway, so this is a temporary setup until then.
Thank you for all of the help on this one - I do appreciate it! :^)
Expert: Darr247 replied at 2024-12-04 10:40:45
430 points EXCELLENT
Well, there are numerous used units of that particular listing from ~$14 and up, but here are some others that appear to be the exact same thing either unbranded or other brand names stamped into / screened onto the plastic box.
In order of price + shipping
http://www.amazon.com/dp/B009GER8A6 ($16.29)
http://www.amazon.com/dp/B005OT3F9U ($16.49)
http://www.amazon.com/dp/B00A0RL2YQ ($16.94)
http://www.amazon.com/dp/B0040TQOMK ($17.99)
Free shipping on orders over $35
http://www.amazon.com/dp/B0086G13PG ($14.99)
http://www.amazon.com/dp/B007S6U7I4 ($16.48)
along with other items having that same qualification...
e.g. if you wanted to add on a couple of Blu-ray discs from the bargain bin, like
Family Guy Star Wars IV-V-VI parody
Swordfish
Heat (De Niro + Pacino)
Donnie Darko
Pulp Fiction
Terminator I,II,III,IV Box Set
Hart's War
Last Samurai
Inception
Prometheus
et al.
Swordfish
Donnie Darko
Pulp Fiction
Hart's War
Last Samurai
Inception
Prometheus
et al.
Author: sirbounty replied at 2024-12-04 04:44:37
Author: sirbounty replied at 2024-12-03 16:32:15
Any other offerings on Amazon? Not exactly sure what specifically to look for, but that one is showing out of stock now. :(
Expert: Darr247 replied at 2024-12-02 16:56:33
I browsed around on monoprice.com, but didn't see a less-expensive way to do it.
Author: sirbounty replied at 2024-12-02 10:27:52
Yes, I have the red/white/yellow cables.
So the only problem I have is the conversion of the digital audio output to the analog input, correct? I just want to be sure I'm getting everything I need to get this working...thanks for the help.
Expert: Darr247 replied at 2024-12-02 10:22:55
Usually, digital coax cables are the same as composite video cables (the ones with the yellow RCA plugs). Do you have one of those?
Author: sirbounty replied at 2024-12-02 06:53:18
Sounds like I need a digital coax AND the converter? All I have are rca cables...
Expert: Darr247 replied at 2024-12-01 12:53:11
Most BD players and DVRs have both coaxial and toslink digital audio outputs... the Sony BDP-S3100 has only a coaxial digital audio output (i.e. besides the digital audio in its HDMI output)... I mentioned the toslink because Amazon offers a combo deal with that converter + a toslink cable (as does that ebay seller), and I was just making sure you realized that a toslink cable wouldn't work with your BD player.
Author: sirbounty replied at 2024-12-01 05:22:45
What am I looking for exactly? Just anything that shows coaxial to rca converter? What's toslink have to do with it? Just trying to find something cheap to get me through the month end, when I'll probably replace this tv with a flat panel.
Expert: Darr247 replied at 2024-11-30 20:39:38
That appears to be the exact same thing, but you'll probably wait 2 to 3 weeks for delivery from china instead of 2 to 3 days for delivery from Amazon. Note how the price bumps up when you choose anything other than just the wallwart power supply from the picklist.
Note also that seller does not offer a tracking number unless you pay an extra $2.50... Personally, I wouldn't buy anything on ebay without a tracking number.
Author: sirbounty replied at 2024-11-30 20:28:42
Would this work, much cheaper, and only as a temp solution until the tv is replaced (soon, I hope)
http://www.ebay.com/itm/Digital-Optical-Coaxial-RCA-Toslink-Signal-to-Analog-Audio-Converter-Adapter-TV-/200957339711?pt=LH_DefaultDomain_0&var=&hash=item2ec9fda83f
Author: sirbounty replied at 2024-11-30 20:25:11
Bluray is BDP-S3100
HDtv is Hitachi 57T600
Expert: Darr247 replied at 2024-11-30 20:15:44
50 points EXCELLENT
Plug the digital coax from the BD player's Digital Audio Out into a box like this digital to analog converter, then a stereo RCA male to RCA male cord from that converter's outputs to the red and white jacks of the INPUT 1 section where the DVI is plugged in.
Amazon offers a toslink combo special with that converter, but it takes an RCA/coax digital cable OR a toslink fiber-optic toslink cable on the input side.
Amazon offers a toslink combo special with that converter, but it takes an RCA/coax digital cable OR a toslink fiber-optic cable on the input side.
Expert: duncanb7 replied at 2024-11-30 19:34:14
Just last try, turn-off HDMI audio on Bluray player on Audio setup menu in order
to let your or other audio up through your connection
and just read tips#4
http://hometheaterreview.com/five-tips-to-successfully-set-up-your-blu-ray-player/
What is model number or name of your HDTV, Could we have a view on its backpanel
by phone photo if the model is too old or hard to find in google ?
Expert: CompProbSolv replied at 2024-11-30 19:04:37
20 points EXCELLENT
Looking at your picture, you have only analog (RCA connector) audio inputs. If your blu-ray player only has digital output, it will be difficult to accommodate.
Expert: CompProbSolv replied at 2024-11-30 19:02:52
duncanb7 is on the right track. There should be an audio input on the TV to go along with the DVI input. It may not be digital, though, which may be the problem.
Your TV has DVI input but not HDMI?
Author: sirbounty replied at 2024-11-30 19:01:15
This is a similar image for the back...I'm plugged into Video 1 (where the dvi is) and tried direct cable from bluray to the one labeled mono in that same block...
http://tinyurl.com/pvuxkfr
Author: sirbounty replied at 2024-11-30 18:54:37
I tried running a single rca cable from the audio out to several of the inputs on the tv, but still no sound.
Maybe I don't fully understand what it is you're saying to do while changing to the input button?
Expert: duncanb7 replied at 2024-11-30 18:26:16
The adapter(HDMI-DVI) works just like a HDMI except that it does not carry audio signals
Need to run audio cable with an optical or coax directly to your receiver ,
and switch the audio on your receiver while changing to your blu-ray player
on your TV input button, just work around this and try it.
There is 5 way for audio connection, just take a look
http://hometheater.about.com/od/hometheaterdoityourself/ss/Five_Ways_To_Access_Audio_From_a_Blu-ray_Disc_Player_5.htm
Hope understand your question completely. If not , please point it out
