When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Tocogroup
at 2024-11-30 05:03:35
Point:500 Replies:11 POST_ID:828848USER_ID:11762
Microsoft Excel Spreadsheet Software;;Microsoft Word
Hi All,
I have an Excel 2010 VBA application in which I open a Word document and save it with a different filename.
When I close the Word document the 'copied' version is still open. It might be obvious but how do I close this 'Doc' file within my VBA code ?
The code looks like this....
Dim WordApp As Object
Dim WordDoc As Object
WordDoc.Save
WordApp.Documents.Add WordDoc.FullName
WordDoc.SaveAs strDocumentName
MsgBox "Your Word document has been saved as " & strDocumentName, vbInformation
WordDoc.Close
WordDoc.Save
WordDoc.Close
Expert: duncanb7 replied at 2024-11-30 06:52:15
Thanks for your pt and Graham's reminder is a key solution in this thread
have a nice day
have a nice day
Author: Tocogroup replied at 2024-11-30 06:49:39
Hi Duncan and Graham,
Thank you both very much for your suggestions regarding wdDoNotSaveChanges.
I'm splitting the points on this one as I combined your codes and got there in the end as well as having understood how it works. It's a big read to close two documents !!
Much appreciated
Toco
Much appreciated
Toco
Expert: duncanb7 replied at 2024-11-30 06:21:52
GrahamSkan is correct,
Tocogroup,Please read it that might help you about late or early binding.
http://www.globaliconnect.com/excel/index.php?option=com_content&view=article&id=169:automate-microsoft-word-from-excel-using-vba&catid=79&Itemid=475
If not, I have no more comment in this thread.
Expert: GrahamSkan replied at 2024-11-30 06:09:44
Can you say what happens with my suggestion, please?
wdDoNotSaveChanges is a constant defined in the Microsoft Word object library, but you are using late binding
Author: Tocogroup replied at 2024-11-30 06:04:06
Neither of your suggestions worked.
The second one didn't recognise the variable wdDoNotSaveChanges
Expert: duncanb7 replied at 2024-11-30 05:51:06
if you just want to close all documents not application, you can try this
'--Loop Through open documentsWith WordAppDo Until .Documents.Count = 0'--Close with save.Documents(1).Close SaveChanges:=wdSaveChanges'--Close no save'--.Documents(1).Close SaveChanges:=wdDoNotSaveChangesLoopEnd With 1:2:3:4:5:6:7:8:9:10:11:12:
Expert: GrahamSkan replied at 2024-11-30 05:46:41
Set the document object when you open it in the first place, otherwise there is confusion about which document is being worked on.
Dim WordApp As Object 'Word.Application Dim WordDoc As Object 'Word.Docunent '... Set WordDoc = WordApp.Documents.Open("C:MyFolderMyFile.doc") WordDoc.SaveAs strDocumentName MsgBox "Your Word document has been saved as " & strDocumentName, vbInformation WordDoc.Close 1:2:3:4:5:6:7:8:9:
Expert: duncanb7 replied at 2024-11-30 05:42:38
Probably, you want to close word application not word document since
you care the copied one is still open
if so, just try this
WordApp.Quit
set WordApp = Nothing
WordApp.Quit
Expert: Saqib Husain, Syed replied at 2024-11-30 05:34:30
Try
wordapp.activedocument.close
Author: Tocogroup replied at 2024-11-30 05:18:55
Fraid it didn't. I got an Error 438 - Object doesn't support this property or method
Expert: duncanb7 replied at 2024-11-30 05:06:05
Is it WordDoc.quit ? it might work
