When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by beardog1113
at 2024-11-28 18:32:58
Point:500 Replies:10 POST_ID:828845USER_ID:11756
Windows 2003 Server;;
Hi
i have installed WSUS 3.0 SP2 in win 2003 server, after i approved office 2010 SP2, i got the error message "the files for this update failed to download. the update can be approved but will not be available to computers until the download is complete, click retry download to start the download again", i tried retry download, but still not working, any advice?
Author: beardog1113 replied at 2024-12-01 23:41:00
Hi
it does not working, the http://technet.microsoft.com/en-us/library/ms162806.aspx, sorry i can not understand....
Expert: duncanb7 replied at 2024-11-28 20:07:20
do you have sqlcmd , try it and read followings, osql may be removed in latest sql server
use sqlcmd instead
http://technet.microsoft.com/en-us/library/ms162773.aspx
you might need to install sql server if no sqlcmd and no MS sql server
so you might download update something relate to sql so that
you has such issue
duncan
use sqlcmd instead
you has such issue
duncan
Expert: duncanb7 replied at 2024-11-28 20:01:24
could you find the file at c: or d: (root dir)
type
dir osql* /s
type
dir osql* /s
Author: beardog1113 replied at 2024-11-28 19:48:29
i also get the solution http://technet.microsoft.com/en-us/library/cc708426(v=ws.10).aspx , as me to To
1.Type: net stop WSUSService, and then press ENTER.
2.Type: "%programfiles%Update Services oolsosqlosql.exe" -S SQL_InstanceName -E -b -n –Q "USE SUSDB update tbConfigurationC set BitsDownloadPriorityForeground=1" and then press ENTER.
3.Type: net start WSUSService.
4.Close the command prompt window and retry synchronization: in the WSUS console, click Options, click Synchronization Options, and then under Tasks, click Synchronize now.
but i did not find "%programfiles%Update Services oolsosqlosql.exe", there is no osql folder under the tools, any advice?
Expert: duncanb7 replied at 2024-11-28 19:34:01
If that's still in issue,
it might be access-right issue, someone change it, if so it is hard to fix it besides
try by error. There is a few report found about this issue in google.
Anway, take a look at this during waiting
http://social.technet.microsoft.com/Forums/windowsserver/en-US/6f4c313c-3f8a-43a2-a641-97fe654b2319/wsus-sp2-unable-to-download-updates-for-windows-2008-r2
Try to save the update to new different destination folder from the default C: WSUS WSUSContent for testing purpose only
the article tells where is content directory about that
http://technet.microsoft.com/en-us/library/cc708545.aspx
Be reminded change it back if not working
Expert: duncanb7 replied at 2024-11-28 19:27:07
Yes, it is good, I will wait here
Author: beardog1113 replied at 2024-11-28 19:25:55
i rebooted the BITS and windows update service,then try download, seems it downloading now, no new error, but not sure if can be completed, let us wait for a moment
Expert: duncanb7 replied at 2024-11-28 19:12:26
What is error message if your try " click retry download to start the download again" ?
same or other
same or other
Author: beardog1113 replied at 2024-11-28 19:05:08
Hi thank you, i tried but not working, i also check che windows log, get the error, "Content file download failed. Reason: The server does not support the necessary HTTP protocol. Background Intelligent Transfer Service (BITS) requires that the server support the Range protocol header.
Source File: /msdownload/update/software/svpk/2013/07/proofmui-fr-fr_5e39e4a6724cc9fa0439c9fd489e9a31f3d01eeb.cab Destination File: e:WSUSWsusContentEB5E39E4A6724CC9FA0439C9FD489E9A31F3D01EEB.cab." EVENT ID 364, could you please help?
Expert: duncanb7 replied at 2024-11-28 18:45:12
it seems your issue is similar to this EE thread, please take a look on it if have time
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Server/2003_Server/Q_26255815.html
http://msmvps.com/blogs/athif/archive/2005/10/27/Purge-Delete-the-downloaded-patches-on-WSUS-Server.aspx
Hope understand your question completely, If not , please point it out
