When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by arcross
at 2024-11-28 05:21:43
Point:500 Replies:1 POST_ID:828841USER_ID:10
Microsoft Visual Basic.Net;;
Hi, Ive got a grid with a few files (.pdfs)and fax numbers so can anybody give me an example of how to use 'faxcomlib' to send these files by fax??
thanks!
thanks!
Expert: duncanb7 replied at 2024-11-30 23:10:29
You can try this example code only, just idea only and Not completed code for your
code starting , other thing you need to analysis and debug it by yourself. It seems it is not easy
Hope understand your question completely. If not please advise it
Imports FAXCOMLibPublic Class Form1Inherits System.Windows.Forms.Form#Region " Windows Form Designer generated code "Public Sub New()MyBase.New()'This call is required by the Windows Form Designer.InitializeComponent()'Add any initialization after the InitializeComponent() callEnd Sub'Form overrides dispose to clean up the component list.Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)If disposing ThenIf Not (components Is Nothing) Thencomponents.Dispose()End IfEnd IfMyBase.Dispose(disposing)End Sub'Required by the Windows Form DesignerPrivate components As System.ComponentModel.IContainer'NOTE: The following procedure is required by the Windows Form Designer'It can be modified using the Windows Form Designer.'Do not modify it using the code editor.Friend WithEvents Button1 As System.Windows.Forms.ButtonFriend WithEvents OpenFileDialog1 As System.Windows.Forms.OpenFileDialogFriend WithEvents Label1 As System.Windows.Forms.Label<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()Me.Button1 = New System.Windows.Forms.Button()Me.OpenFileDialog1 = New System.Windows.Forms.OpenFileDialog()Me.Label1 = New System.Windows.Forms.Label()Me.SuspendLayout()''Button1'Me.Button1.Location = New System.Drawing.Point(80, 89)Me.Button1.Name = "Button1"Me.Button1.Size = New System.Drawing.Size(128, 23)Me.Button1.TabIndex = 0Me.Button1.Text = "Select File To Send"''Label1'Me.Label1.Font = New System.Drawing.Font("Microsoft Sans Serif", 14.25!, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, CType(0, Byte))Me.Label1.Location = New System.Drawing.Point(24, 33)Me.Label1.Name = "Label1"Me.Label1.Size = New System.Drawing.Size(240, 23)Me.Label1.TabIndex = 1Me.Label1.Text = "Send File To Fax"Me.Label1.TextAlign = System.Drawing.ContentAlignment.MiddleCenter''Form1'Me.AcceptButton = Me.Button1Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)Me.ClientSize = New System.Drawing.Size(292, 144)Me.Controls.AddRange(New System.Windows.Forms.Control() {Me.Label1, Me.Button1})Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedToolWindowMe.Name = "Form1"Me.Text = "FaxIt"Me.ResumeLayout(False)End Sub#End RegionPrivate Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.ClickTryDim fo As New OpenFileDialog()fo.Filter = "Microsoft Word Document (*.doc)|*.doc| Adobe PDF (*.pdf)|*.pdf"If fo.ShowDialog = DialogResult.OK ThenIf fo.FileName = "" ThenExit SubEnd IfElseExit SubEnd IfDim fxsvr = New FAXCOMLib.FaxServer()Dim fxdoc = fxsvr.CreateDocument(fo.FileName)Tryfxsvr.Connect("KEITH" 'Machine NameCatch ex As ExceptionMessageBox.Show(ex.ToString())End Tryfxdoc.FileName = fo.FileNamefxdoc.FaxNumber = InputBox("Fax Number:", "Enter Fax Number", -1, -1)fxdoc.RecipientName = ""Tryfxdoc.Send()Catch ex As ExceptionMessageBox.Show(ex.ToString())End Tryfxsvr.Disconnect()Catch ex As ExceptionMessageBox.Show(ex.message() & ControlChars.CrLf & ControlChars.CrLf & ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)End TryEnd SubEnd Class 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:102:103:104:105:106:107:108:109:110:111:112:113:114:115:116:117:118:119:120:121:122:123:124:125:126:
