When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by burnedfaceless
at 2024-11-27 19:26:16
Point:500 Replies:5 POST_ID:828836USER_ID:11745
Cascading Style Sheets (CSS);;
If I wanted the following to be canceled what would the syntax be?
border: 2px solid #000;
border: none;
border: none;
Expert: duncanb7 replied at 2024-11-28 14:13:31
Thanks for your pt
Author: burnedfaceless replied at 2024-11-28 14:04:27
Expert: nanharbison replied at 2024-11-28 07:41:33
As DaveBaldwin says, f you replace the CSS for the border, it has to be the last CSS rule read by the page, so the style sheet that contains border:none has to come after the previous border rule.
But also, is your replacement rule in a separate style sheet, so you can look at the html on the page and make sure the replacement rule style sheet is last?
Or have you embedded this replacement rule in the html on one particular page, which comes after rules on a style sheet.? Or you can do it inline right in the div or whatever needs the replacement rule. That rule is the last one read.
Expert: duncanb7 replied at 2024-11-27 23:52:01
I think you want to control CSS style in your page for some html tags or area individually
and effeciently. If so,
you might be interested in the following articles about CSS style precedence
http://www.vanseodesign.com/css/css-specificity-inheritance-cascaade/
http://css-tricks.com/specifics-on-css-specificity/
http://www.w3.org/TR/CSS2/cascade.html
Hope understand your question completely. If not please point it out
Expert: Dave Baldwin replied at 2024-11-27 20:40:22
You can't 'cancel' a CSS declaration but you can replace it. CSS definitions are applied in the order that they are found on a page. If you have a <style> section and a CSS file link in the <head>, the one that comes Last (for any particular element) is the one that is applied. After that, any 'inline' 'style' attributes are applied.
Note that if you change the color with 'border-color', that's all that it changes. The width and style remain the same until you change them.
