When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by mbudman
at 2024-11-27 12:57:25
Point:500 Replies:8 POST_ID:828834USER_ID:11742
Web Services;;Web Servers
Hello,
I have a customer who hosts their web site through a company that specializes in Web sites.
The customer's website goes down on average (i.e. is not available) once every 6 weeks.
Is there any type of software that I can implement that can monitor the health of the web site so as to let someone (of my choosing) know if the web site goes down and becomes unavailable ?
The failure of the website is not the code, it is strictly a failure on the part of the web hosting company.
Thanks in advance.
Mark
Thanks in advance.
Mark
Author: mbudman replied at 2024-12-16 08:54:13
Thank you. This is exactly what I was looking for.
Cheers,
Mark
Cheers,
Mark
Author: mbudman replied at 2024-12-16 08:53:25
Thank you for your help.
Mark
Mark
Expert: Kimputer replied at 2024-12-16 08:39:30
Go to http://kimputer.is-a-geek.com/tools/sitecheck/
Download both files.
Adjust config.ini
[GLOBAL]
host= fill in open smtp host you have access to. Either from your own provider, or the target smtp server
to=where does the email go to
from=what do you want in the from: header
total= adjust this number to the amount of entries under here, in this case 2
[1]
label=(label inside the program so you can see quickly for which site it is)
url= (notice if site is auto forwarded that you use the end url, not the start url)
interval=15 (interval in minutes to check this site, more important sites lower, less important higher)
string=unique_string (inside the HTML code, find a unique string, so you know this site is really up, if you fill in error, it might not be so smart, if php or mysql errors occur, it will still say the site is up.).
[2]
label=label2
url=http://test.com
interval=15
string=test.com
[3]
etc..
Just run the program, and keep the session open (don't log off), and you will be fine!
Adjust config.ini
[GLOBAL]
[1]
[2]
label=label2
url=http://test.com
interval=15
string=test.com
[3]
etc..
Author: mbudman replied at 2024-12-16 06:59:42
Hi Kimputer,
I am very interested in finding out about your program. How can we go about the next step?
Thanks,
Mark
Thanks,
Mark
Expert: Scott Fell (padas) replied at 2024-11-28 20:53:18
I have been testing pingdomm https://www.pingdom.com/ and it works nicely. I get a sms and email when the site goes down although this has always been from windows auto restart after installing patch's.
Expert: Kimputer replied at 2024-11-28 05:32:08
I have written my own very simple Lazarus/Delphi program for that. It just queries a list of websites (currently 10 max), and checks on one keyword. If it's not there (for instance, mysql error preventing page from loading, but of course, also full website down, unable to connect), it will turn some green dots to red in the gui, and email to one person which site of the list isn't up anymore. Since it's very simple, it needs to run on a PC that's always on and logged in.
Let me know if you're interested.
Expert: serialband replied at 2024-11-27 14:36:14
Here's another free service not listed in Duncan's link.
http://www.amiup.co.uk/
Depending on your access, you could also run a script on the server itself that notifies you when it's still running and if the system has been restarted. You could have it send you the system uptime to let you know when it's been rebooted.
Expert: duncanb7 replied at 2024-11-27 14:27:20
Normally, if it is not completed server shut down. Most
hosting company will provide a notice webpage to its
website sever customer when its server is going to
1-Doing server maintenace
2-partial or some servers are in problem
3-Unexpected issue on server and need temporarily shut down for
part of servers .
The page will show you once your website is going to those issue
and let other veiwers to view your site to be aware of the notice message
and they will come back later on to continue to view.
If you need website monitor server, you can find it more in google easily , for example link
http://mashable.com/2008/08/25/free-and-cheap-website-monitoring-services/
Hope understand your question completely. If not please point it out
part of servers .
