When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by etech0
at 2024-11-18 08:35:43
Point:500 Replies:6 POST_ID:828809USER_ID:11713
Cascading Style Sheets (CSS);Web Browsers;Miscellaneous Web Development
Hi!
I'm having a problem with the CSS on a webpage. I'm using an ordered list, and in chrome and firefox the numbers show fine. However, in Internet Explorer the numbers do not show up at all.
Can anyone please help me figure this out?
Here's the page: http://goinspire.com/10-places-dont-want-stay-visiting-israel/
Thanks!
Thanks!
Expert: ModeIT replied at 2024-11-18 23:23:04
Thread Cleansed
MIT
MIT
Author: etech0 replied at 2024-11-18 09:38:49
All fixed - thanks for your help!
Expert: Gary replied at 2024-11-18 09:33:32
Ok, just realised you have separate OL's
Remove the inside declaration and leave it as outside.
To your first OL add
width:380px;
display:inline-block;
@duncanb7
Do not be telling people to make their code invalid - every element needs to be closed.
And http://sscce.org/ is irrelevant here - he has posted his website link
width:380px;
@duncanb7
Author: etech0 replied at 2024-11-18 09:03:23
Gary: That fixed it! Thanks...
One more question: now, the second line of the li items is not indented correctly - I don't want to see the words under the numbers. How do I fix that?
Thanks!
Thanks!
Expert: duncanb7 replied at 2024-11-18 08:58:22
taking </li> for all li tags, it will work for IE
<!doctype html><html lang="en"> <head> <title>li question</title> </head> <body> <ol> <li>Item 1 <li>Item 2 </ol> </body></html> 1:2:3:4:5:6:7:8:9:10:11:12:
Expert: Gary replied at 2024-11-18 08:54:49
Change/set the list style position to inside (not outside)
