When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by tobece
at 2024-11-18 02:39:19
Point:500 Replies:9 POST_ID:828804USER_ID:11711
PHP Scripting Language;;Scripting Languages
Hi all,
I have this array:
I have this array:
Array( [0] => "**MAIN ITEM**" [1] => "*Self Defense*" [2] => "Pepper Spray|50|" [3] => "Stun Gun|75|" [4] => "A Hammer|20|" [5] => "*Sports*" [6] => "Baseball Cap|22|" [7] => "DuoGolf Stick|175|" [8] => "Portable Pool|1165|" [9] => "**ADDITIONAL ITEM**" [10] => "*Food & Drinks*" [11] => "Sprite|11|" [12] => "7 Up|10|" [13] => "Coca Cola|9|" [14] => "**MISC ITEM**" [15] => "*Kids*" [16] => "Pair of Baloons|2|" [17] => "Rubber Car Toy|11|" [18] => "China Toy|15|") 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:
Can you help me re-arrange above array into this:
Array( [0] =>" "MAIN ITEM|Self Defense|Pepper Spray|50|" [1] =>" "MAIN ITEM|Self Defense|Stun Gun|75|" [2] =>" "MAIN ITEM|Self Defense|A Hammer|20|" [3] =>" "MAIN ITEM|Sports|Baseball Cap|22|" [4] =>" "MAIN ITEM|Sports|DuoGolf Stick|175|" [5] =>" "MAIN ITEM|Sports|Portable Pool|1165|" [6] =>" "ADDITIONAL ITEM|Food &" Drinks|Sprite|11|" [7] =>" "ADDITIONAL ITEM|Food &" Drinks|7 Up|10|" [8] =>" "ADDITIONAL ITEM|Food &" Drinks|Coca Cola|9|" [9] =>" "MISC ITEM|Kids|Pair of Baloons|2|" [10] =>" "MISC ITEM|Kids|Rubber Car Toy|11|" [11] =>" "MISC ITEM|Kids|China Toy|15|") 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
And also into a multidimensional array like this:
Array( [MAIN ITEM] =>" array ( [Self Defense] =>" array ( [0] =>" "Pepper Spray|50|", [1] =>" "Stun Gun|75|", [2] =>" "A Hammer|20|" ), [Sports] =>" array ( [0] =>" "Baseball Cap|22|", [1] =>" "DuoGolf Stick|175|", [2] =>" "Portable Pool|1165|" ) ), [ADDITIONAL ITEM] =>" array ( [Food &" Drinks] =>" array ( [0] =>" "Sprite|11|", [1] =>" "7 Up|10|", [2] =>" "Coca Cola|9|" ) ), [MISC ITEM] =>" array ( [Kids] =>" array ( [0] =>" "Pair of Baloons|2|", [1] =>" "Rubber Car Toy|11|", [2] =>" "China Toy|15|" ) )) 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:
Basically I'm just learning into arrays and would like to know how to convert/re-arrange the first one into 2 kinds of arrays.
I've been playing around with foreach, preg_match, substr, but seems that I cant find a way to split and re-array it :(
Please help me ... Thanks.
Expert: Ray Paseur replied at 2024-11-18 06:06:08
Thanks for the points. With MySQLi (and maybe PDO, not sure) you car retrieve rows of data from a data base query in the form of an object.
http://php.net/manual/en/mysqli-result.fetch-object.php
The column names are the names of the properties in the object. And you can create an object instance of any class you want from the results set. This implies the ability to have object methods that use the results set automatically. One example might be a data base that contained locations provided by a personnel sensor. Upon querying the data base, the retrieved rows could automatically inject themselves into a master object to calculate directions and distances traveled by the sensor. In a population of many sensors, this could enable you to detect when a person had left the group, etc.
Expert: duncanb7 replied at 2024-11-18 05:58:50
Thanks your pt, I thought no pt since Ray_Paseur posted out with
his perfect code
it is good at least encourge people post out actively if they understand
the question & know the solution completely
have a nice day
his perfect code
have a nice day
Author: tobece replied at 2024-11-18 05:52:30
Really perfect results I received here ... :)
Author: tobece replied at 2024-11-18 05:50:59
Really thanks a lot Ray... I really really have to learn a lot from you for cleaner & shorter codes.
And also, the last solution is very nice which turns its output like pulling datas from MySQL :)
At first I was thinking of a solution like @duncanb7 until it get so complex and I cant handle it :(
Thanks all ...
Thanks all ...
Expert: Ray Paseur replied at 2024-11-18 05:29:33
450 points EXCELLENT
Here is a third example, starting at line 95. It teaches how to make an array of objects. With data-only structures like this, the array of objects has the advantage of simpler syntax and punctuation. When you add class methods, the objects can take on a life of their own with all kinds of built-in functionality (think rows in a data base table, automatic tax calculations, etc). This is not something that is available from arrays alone. If you get very far in your programming studies, you will find the array of objects to be one of the most useful data constructs!
<?php // RAY_temp_tobece.phperror_reporting(E_ALL);echo '<pre>';// STARTING TEST DATA SET$arr = Array( 0 => "**MAIN ITEM**" , 1 => "*Self Defense*" , 2 => "Pepper Spray|50|" , 3 => "Stun Gun|75|" , 4 => "A Hammer|20|" , 5 => "*Sports*" , 6 => "Baseball Cap|22|" , 7 => "DuoGolf Stick|175|" , 8 => "Portable Pool|1165|" , 9 => "**ADDITIONAL ITEM**" , 10 => "*Food & Drinks*" , 11 => "Sprite|11|" , 12 => "7 Up|10|" , 13 => "Coca Cola|9|" , 14 => "**MISC ITEM**" , 15 => "*Kids*" , 16 => "Pair of Baloons|2|" , 17 => "Rubber Car Toy|11|" , 18 => "China Toy|15|");// DOES IT LOOK RIGHT? YESprint_r($arr);// DOUBLE STAR IS FIRST CATEGORY, SINGLE STAR IS SECOND CATEGORY, NO STAR IS LIST ITEM$new = array();foreach ($arr as $str){ if (substr($str,0,2) == '**') { $first = $str; } elseif (substr($str,0,1) == '*') { $second = $str; } else { $new[] = str_replace('*', NULL, $first) . '|' . str_replace('*', NULL, $second) . '|' . $str; }}// DOES IT LOOK RIGHT? YES.print_r($new);// REVERSE THE ARRAY AND WORK UP FROM THE BOTTOM$arr = array_reverse($arr);// COLLECT THE SUB-ARRAYS HERE$sub = array();$end = array();$out = array();foreach ($arr as $str){ if (substr($str,0,2) == '**') { $cat = str_replace('*', NULL, $str); $out[$cat] = array_reverse($sub); $sub = array(); } elseif (substr($str,0,1) == '*') { $key = str_replace('*', NULL, $str); $sub[$key] = array_reverse($end); $end = array(); } else { $end[] = $str; }}// REVERSE THE ARRAY TO ORIGINAL ORDER$out = array_reverse($out);// DOES IT LOOK RIGHT? YES.print_r($out);// SHOW HOW TO MAKE AN ARRAY OF OBJECTSClass Item{ public function __construct($item, $dlm = '|') { $item = explode($dlm, $item); $this->main = $item[0]; $this->subcat = $item[1]; $this->name = $item[2]; $this->price = $item[3]; }}// USE THE FIRST ARRAY WE CONSTRUCTEDforeach ($new as $str){ $objs[] = new Item($str);}print_r($objs);// SHOW HOW TO FIND THE "Sports" ITEMSforeach ($objs as $obj){ if ($obj->subcat == 'Sports') { echo PHP_EOL . "$obj->name PRICED AT $obj->price"; }} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:102:103:104:105:106:107:108:109:110:111:112:113:114:115:116:117:118:119:120:121:
HTH, ~Ray
Expert: Ray Paseur replied at 2024-11-18 04:59:05
Here is the second example. It starts on line 60.
<?php // RAY_temp_tobece.phperror_reporting(E_ALL);echo '<pre>';// STARTING TEST DATA SET$arr = Array( 0 => "**MAIN ITEM**" , 1 => "*Self Defense*" , 2 => "Pepper Spray|50|" , 3 => "Stun Gun|75|" , 4 => "A Hammer|20|" , 5 => "*Sports*" , 6 => "Baseball Cap|22|" , 7 => "DuoGolf Stick|175|" , 8 => "Portable Pool|1165|" , 9 => "**ADDITIONAL ITEM**" , 10 => "*Food & Drinks*" , 11 => "Sprite|11|" , 12 => "7 Up|10|" , 13 => "Coca Cola|9|" , 14 => "**MISC ITEM**" , 15 => "*Kids*" , 16 => "Pair of Baloons|2|" , 17 => "Rubber Car Toy|11|" , 18 => "China Toy|15|");// DOES IT LOOK RIGHT? YESprint_r($arr);// DOUBLE STAR IS FIRST CATEGORY, SINGLE STAR IS SECOND CATEGORY, NO STAR IS LIST ITEM$out = array();foreach ($arr as $str){ if (substr($str,0,2) == '**') { $first = $str; } elseif (substr($str,0,1) == '*') { $second = $str; } else { $out[] = str_replace('*', NULL, $first) . '|' . str_replace('*', NULL, $second) . '|' . $str; }}// DOES IT LOOK RIGHT? YES.print_r($out);// REVERSE THE ARRAY AND WORK UP FROM THE BOTTOM$arr = array_reverse($arr);// COLLECT THE SUB-ARRAYS HERE$sub = array();$end = array();$out = array();foreach ($arr as $str){ if (substr($str,0,2) == '**') { $cat = str_replace('*', NULL, $str); $out[$cat] = array_reverse($sub); $sub = array(); } elseif (substr($str,0,1) == '*') { $key = str_replace('*', NULL, $str); $sub[$key] = array_reverse($end); $end = array(); } else { $end[] = $str; }}// REVERSE THE ARRAY TO ORIGINAL ORDER$out = array_reverse($out);// DOES IT LOOK RIGHT? YES.print_r($out); 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:
Expert: duncanb7 replied at 2024-11-18 04:40:00
50 points EXCELLENT
Dear tobece,
the following code is working for your first request completely and I tried and it works
for multidimensional array, I think you can handle based on the following code
Hope it will help
Hope it will help
<?php$arr=Array( "**MAIN ITEM**", "*Self Defense*", "Pepper Spray|50|", "Stun Gun|75|", "A Hammer|20|", "*Sports*", "Baseball Cap|22|", "DuoGolf Stick|175|", "Portable Pool|1165|", "**ADDITIONAL ITEM**", "*Food & Drinks*", "Sprite|11|", "7 Up|10|", "Coca Cola|9|", "**MISC ITEM**", "*Kids*", "Pair of Baloons|2|", "Rubber Car Toy|11|", "China Toy|15|");$cnt=count($arr); $mline=array();$i=0;for( $a=0;$a<$cnt;$a++){if( stripos("#".$arr[$a],"**")>0){$mline[$i]=$arr[$a]; $i=$i+1;}}$kline=array();$jline=array();$i=0;$j=0;$k=0;for( $a=0;$a<$cnt;$a++){if (@stripos("#".$arr[$a+1],"**")>0)$i=$i+1;if( stripos("#".$arr[$a],"*")>0 && stripos("#".$arr[$a],"**")==false){$kline[$j]=$arr[$a];for( $b=0;$b<$cnt;$b++){if($arr[$b]==$kline[$j]){break;}}for( $c=$b+1;$c<$cnt;$c++){if(stripos("#".$arr[$c],"*")>0) break;$jinal[$k]=$mline[$i]."|".$kline[$j]."|".$arr[$c];$jline[$k]=str_replace("*","",$jinal[$k]);$k=$k+1;}$j=$j+1;}}print_r($jline);?> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:
Expert: Ray Paseur replied at 2024-11-18 04:29:38
Here's the first example.
<?php // RAY_temp_tobece.phperror_reporting(E_ALL);echo '<pre>';// STARTING TEST DATA SET$arr = Array( 0 => "**MAIN ITEM**" , 1 => "*Self Defense*" , 2 => "Pepper Spray|50|" , 3 => "Stun Gun|75|" , 4 => "A Hammer|20|" , 5 => "*Sports*" , 6 => "Baseball Cap|22|" , 7 => "DuoGolf Stick|175|" , 8 => "Portable Pool|1165|" , 9 => "**ADDITIONAL ITEM**" , 10 => "*Food & Drinks*" , 11 => "Sprite|11|" , 12 => "7 Up|10|" , 13 => "Coca Cola|9|" , 14 => "**MISC ITEM**" , 15 => "*Kids*" , 16 => "Pair of Baloons|2|" , 17 => "Rubber Car Toy|11|" , 18 => "China Toy|15|");// DOES IT LOOK RIGHT?print_r($arr);// DOUBLE STAR IS FIRST CATEGORY, SINGLE STAR IS SECOND CATEGORY, NO STAR IS LIST ITEM$out = array();foreach ($arr as $str){ if (substr($str,0,2) == '**') { $first = $str; } elseif (substr($str,0,1) == '*') { $second = $str; } else { $out[] = str_replace('*', NULL, $first) . '|' . str_replace('*', NULL, $second) . '|' . $str; }}// DOES IT LOOK RIGHTprint_r($out); 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:
Expert: Ray Paseur replied at 2024-11-18 04:17:24
For a collection of good learning resources, for anyone starting PHP, these two articles will be helpful. Have a read, and while you do that I'll try to set up some code examples.
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/A_11769-And-by-the-way-I-am-new-to-PHP.html
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/A_12293-AntiPHPatterns-and-AntiPHPractices.html
