When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by bledington
at 2024-11-17 09:22:56
Point:500 Replies:5 POST_ID:828803USER_ID:11710
Microsoft Hardware;;
I have a strange problem with my laptop. The actual location of the @ and ". The @ is on the top left above the number 2 and types as". The " key is above the ' key and types as @.
I am in the UK and my regional and language settings are correct. How can I get the keys to function properly?
Expert: duncanb7 replied at 2024-11-18 00:52:40
thanks
have a nice day
have a nice day
Expert: rindi replied at 2024-11-17 10:38:18
If you don't change to the UK keyboard layout and rather want to stay with the US layout, it is probably shift + 4.
Author: bledington replied at 2024-11-17 10:20:40
Thanks this is great!! How do I get a UK pound sign rather than a $ symbol? Tony
Expert: rindi replied at 2024-11-17 09:55:48
In the control panel of your OS may sure you have selected the proper keyboard for UK layout. At the moment it looks as if it is set to the US layout. Sometimes, if you have installed more than one layout, you'll also find an option in your taskbar where you can change the selected keyboard layout.
Expert: duncanb7 replied at 2024-11-17 09:29:31
Could you follow this link and reset computer ?
http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
Hope it help for rest keyboard layout assignment
