When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Maliki Hassani
at 2024-11-15 06:57:21
Point:500 Replies:5 POST_ID:828793USER_ID:11697
Oracle Database;;SQL Query Syntax
Experts,
I have a field called "Request_ID", that contains two merged Request ID's in the form of "000000001098990|000000029558106". I would like to only show all values before the "|". So show only "000000001098990". Is there a way to do this?
this works but, is this the best way because what if the amount of values increase?
SUBSTR ((AU.request_id),0,(LENGTH(AU.request_id)-16)) AS REQUEST_ID_MOD,
Current ouput:
TKT-1412155 000000001098990|000000029558106
TKT-1412155 000000001098970|000000029558106
TKT-1412155 000000001098991|000000029558106
TKT-1412155 000000001098957|000000029558106
Needing ouput:
Current ouput:
Needing ouput:
Author: Maliki Hassani replied at 2024-11-18 14:42:01
Thanks!
Expert: slightwv replied at 2024-11-18 14:31:10
duncanb7,
Oracle doesn't have a SUBSTRING_INDEX function.
Expert: duncanb7 replied at 2024-11-15 07:08:23
SELECT SUBSTRING_INDEX(Request_ID, '|', 1)
it will get the value 000000001098990
////////////////////-------SELECT SUBSTRING_INDEX(Request_ID, '|', 2)
///////////////////--------it will get the value 000000029558106
Hope it works for you
Author: Maliki Hassani replied at 2024-11-15 07:05:48
Thank you!
Expert: Steve Wales replied at 2024-11-15 07:04:16
The INSTR function returns the first occurrence of a character in a string.
So, you could do something like:
select substr(col1,1,instr(col1,'|')-1)
This will take a substring of your output string, up to the character before the position of the '|'.
(Assuming that the | character that separates them is always going to be the first occurrence).
