When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by nchoful
at 2024-11-15 03:27:50
Point:500 Replies:5 POST_ID:828788USER_ID:11689
Web Services;;
i registered two domains with godaddy recently. ie afrilinkconsult.com and afrilinksecurities.com. i i also bought a web hosting. i was told the hosting can host unlimited domains. my understanding was that i could host different domains with different web contents all at once.
i realised that after hosting the afrilinkconsult.com, if i open the page to afrilinksecurities.com, it takes me to the same pge as afrilinkconsult.com
do i have to buy anothe hosting for afrilinksecurities.com? if yes, what does godaddy mean when they say thehosting is for unlimited websites.
Author: nchoful replied at 2024-11-15 22:02:00
Okay Duncan. Thanks for your advice. Cheers.
Expert: Scott Fell (padas) replied at 2024-11-15 21:48:30
200 points EXCELLENT
Placing multiple domains on your site and having multiple separate sites are two different things. You of course want to avoid having multiple domains point to the same site. There is no value in that. If you do go with mulitple domain names on one host service, you need to make sure you 301 redirect to just the main domain.
If you are using shared hosting spending $3 to $20 per month, get a separate hosting service for each separate website.
Expert: duncanb7 replied at 2024-11-15 05:13:29
Yes, of course, you can have 10000000 domain name with on only one hosting account
but you need to ask them whether they are willing to do that for you for
the setup on your server if too many domain name.
If they don't do it for you OR they just help you to do less than three domain
name, you need to do it by yourself on your linux server through SSH
Author: nchoful replied at 2024-11-15 05:05:15
Okay. i will notify them to help me out. i only wanted to know whether several websites can be on one hosting account. Thanks a lot
Expert: duncanb7 replied at 2024-11-15 04:49:05
300 points EXCELLENT
You should contact Admin or Supoort from your hosting company
Normally, hosting company will provide at least two free domian name
for you when you become its new member. And you can ask them to help
you for DNS and Apache Virtual Host setup on Linux server.
I think godaddy, hosting service company, will help you to do DNS/Virtual setup
for your unlimited website domain if you have and want to host on your one user account
In other words, you just need one hosting account that can host unlimited website domain with your account on VPS server or Shared server
I have one hosting account and I do setup by myself on root linux to
host unlimited domain name to my server ( which is owned by my hosting account)
Hope you understand what I say
