When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-12 03:20:05
Point:500 Replies:9 POST_ID:828786USER_ID:11059
Linux;PHP Scripting Language;C++ Programming Language
I have been trying to install Hiphop (VM) on my VPS linux-64 Centos server during
the whole week and overcame a lot of installation issues.
Now at latest stage of my installation is finished closing to 72%
from make command at the final step in which the error is echo out as follows
about "elfwrite.cpp.o" related to Dwarf and /usr/include/libdwarf library.
After I have re-installed all third-party lib again about
1-yum install elfutils-libelf-devel
2- install libdwarf based on other website suggestion
3- install libelf based on other website suggestion
And then re-do the following command:
export CC=gcc
export CMAKE_PREFIX_PATH=`pwd`/local
cd hiphop-php
git submodule init
git submodule update
export HPHP_HOME=`pwd`
export HPHP_LIB=`pwd`/bin
cmake .
make
That it is still echo out the same error about elfwriter.cpp, please help
me to overcome this error if you are familar with hiphop installation and
I am appreciated your help.
Below I will attach my shell script and error outout
Error out for elfwriter.cpp on Line 57 and 63
export CC=gcc
cd hiphop-php
git submodule init
cmake .
make
root@vps [/home/dev/hiphop]# cd hiphop-phproot@vps [/home/dev/hiphop/hiphop-php]# make[ 3%] Built target folly[ 4%] Built target double-conversion[ 4%] Built target gen-class-map[ 4%] Built target gen-ext-hhvm[ 5%] Built target gen-infotabs[ 5%] Built target afdt[ 12%] Built target mbfl[ 12%] Built target sqlite3[ 13%] Built target timelib[ 13%] Built target lz4[ 16%] Built target hphp_thrift[ 17%] Built target hphp_proxygen[ 18%] Built target vixl[ 19%] Built target neo[ 19%] Built target hphp_parser[ 20%] Built target hphp_zend[ 25%] Built target hphp_util[ 25%] Built target hphp_system[ 26%] Built target hphp_hhbbc[ 35%] Built target hphp_analysis[ 35%] Building CXX object hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.oIn file included from /home/dev/hiphop/local/include/boost/interprocess/sync/interprocess_mutex.hpp:31:0, from /home/dev/hiphop/local/include/boost/interprocess/sync/interprocess_upgradable_mutex.hpp:22, from /home/dev/hiphop/hiphop-php/hphp/util/base.h:60, from /home/dev/hiphop/hiphop-php/hphp/runtime/base/types.h:20, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.h:19, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp:16:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/mutex.hpp: In member function ‘void boost::interprocess::ipcdetail::posix_mutex::unlock()’:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/mutex.hpp:141:8: warning: variable ‘res’ set but not used [-Wunused-but-set-variable] int res = 0; ^In file included from /home/dev/hiphop/local/include/boost/interprocess/sync/interprocess_condition.hpp:30:0, from /home/dev/hiphop/local/include/boost/interprocess/sync/interprocess_upgradable_mutex.hpp:23, from /home/dev/hiphop/hiphop-php/hphp/util/base.h:60, from /home/dev/hiphop/hiphop-php/hphp/runtime/base/types.h:20, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.h:19, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp:16:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp: In destructor ‘boost::interprocess::ipcdetail::posix_condition::~posix_condition()’:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp:146:9: warning: variable ‘res’ set but not used [-Wunused-but-set-variable] int res = 0; ^/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp: In member function ‘void boost::interprocess::ipcdetail::posix_condition::notify_one()’:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp:153:9: warning: variable ‘res’ set but not used [-Wunused-but-set-variable] int res = 0; ^/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp: In member function ‘void boost::interprocess::ipcdetail::posix_condition::notify_all()’:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp:160:9: warning: variable ‘res’ set but not used [-Wunused-but-set-variable] int res = 0; ^/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp: In member function ‘void boost::interprocess::ipcdetail::posix_condition::do_wait(boost::interprocess::ipcdetail::posix_mutex&)’:/home/dev/hiphop/local/include/boost/interprocess/sync/posix/condition.hpp:168:8: warning: variable ‘res’ set but not used [-Wunused-but-set-variable] int res = 0; ^/home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp: In member function ‘bool HPHP::Debug::ElfWriter::initDwarfProducer()’:/home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp:106:11: error: invalid conversion from ‘int (*)(char*, int, Dwarf_Unsigned, Dwarf_Unsigned, Dwarf_Unsigned, Dwarf_Unsigned, Dwarf_Unsigned*, Dwarf_Ptr, int*) {aka int (*)(char*, int, long long unsigned int, long long unsigned int, long long unsigned int, long long unsigned int, long long unsigned int*, void*, int*)}’ to ‘Dwarf_Callback_Func_c {aka int (*)(const char*, int, long long unsigned int, long long unsigned int, long long unsigned int, long long unsigned int, long long unsigned int*, void*, int*)}’ [-fpermissive] &error); ^In file included from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/dwarf.h:23:0, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.h:20, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp:16:/usr/include/libdwarf.h:2294:15: error: initializing argument 2 of ‘Dwarf_P_Debug_s* dwarf_producer_init_c(Dwarf_Unsigned, Dwarf_Callback_Func_c, Dwarf_Handler, Dwarf_Ptr, void*, Dwarf_Error_s**)’ [-fpermissive] Dwarf_P_Debug dwarf_producer_init_c( ^In file included from /home/dev/hiphop/local/include/boost/filesystem/path_traits.hpp:23:0, from /home/dev/hiphop/local/include/boost/filesystem/path.hpp:25, from /home/dev/hiphop/local/include/boost/filesystem/operations.hpp:25, from /home/dev/hiphop/hiphop-php/hphp/util/base.h:63, from /home/dev/hiphop/hiphop-php/hphp/runtime/base/types.h:20, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.h:19, from /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp:16:/home/dev/hiphop/local/include/boost/system/error_code.hpp: At global scope:/home/dev/hiphop/local/include/boost/system/error_code.hpp:214:36: warning: ‘boost::system::posix_category’ defined but not used [-Wunused-variable] static const error_category & posix_category = generic_category(); ^/home/dev/hiphop/local/include/boost/system/error_code.hpp:215:36: warning: ‘boost::system::errno_ecat’ defined but not used [-Wunused-variable] static const error_category & errno_ecat = generic_category(); ^/home/dev/hiphop/local/include/boost/system/error_code.hpp:216:36: warning: ‘boost::system::native_ecat’ defined but not used [-Wunused-variable] static const error_category & native_ecat = system_category(); ^make[2]: *** [hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o] Error 1make[1]: *** [hphp/runtime/CMakeFiles/hphp_runtime_static.dir/all] Error 2make: *** [all] Error 2 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:
HipHop Installation shell script on linux-x86-64-CentOS:
#!/bin/bashcd hiphopgit clone git://github.com/facebook/hiphop-php.gitwget "http://downloads.sourceforge.net/project/re2c/re2c/0.13.5/re2c-0.13.5.tar.gz?use_mirror=cdnetworks-us-2"cp /home/dev/tbb40_20120613oss_src.tgz .#wget "http://www.threadingbuildingblocks.org/uploads/77/142/2.2/tbb22_20090809oss_src.tgz"wget "http://curl.haxx.se/download/curl-7.20.0.tar.bz2"wget "http://www.monkey.org/~provos/libevent-1.4.14-stable.tar.gz"wget "http://launchpad.net/libmemcached/1.0/0.48/+download/libmemcached-0.48.tar.gz"wget "http://download.icu-project.org/files/icu4c/4.6.1/icu4c-4_6_1-src.tgz"wget "http://www.geocities.jp/kosako3/oniguruma/archive/onig-5.9.2.tar.gz"#wget "http://downloads.sourceforge.net/project/boost/boost/1.46.1/boost_1_46_1.tar.gz?r=http%3A%2F%2Fsourceforge.net%2Fprojects%2Fboost%2Ffiles%2Fboost%2F1.46.1%2F&"use_mirror=ignum"cp /home/dev/boost_1_50_0.tar.gz .wget "http://php.webtutor.pl/wp-content/uploads/2011/04/libcclient2007-devel.tar.gz"cp /home/dev/libelf-0.8.9.tar.gz .tar xf libelf-0.8.9.tar.gzcd libelf-0.8.9./configure --prefix=../localmake -j 8make installcd ..tar xvjf curl-7.20.0.tar.bz2tar xvzf libevent-1.4.14-stable.tar.gztar xvzf re2c-0.13.5.tar.gztar xvzf tbb40_20120613oss_src.tgztar xvzf libmemcached-0.48.tar.gztar xvzf icu4c-4_6_1-src.tgztar xvzf onig-5.9.2.tar.gztar xvzf boost_1_50_0.tar.gztar xvzf libcclient2007-devel.tar.gzexport CC=gccexport CMAKE_PREFIX_PATH=`pwd`/localgit clone git://libdwarf.git.sourceforge.net/gitroot/libdwarf/libdwarfcd libdwarf/libdwarf./configuremakesudo cp libdwarf.a /usr/lib64/sudo cp libdwarf.h /usr/include/sudo cp dwarf.h /usr/include/cd ../..cd tbb40_20120613ossgmakecp -Rp include/tbb/ /usr/include/cp `pwd`/build/*_release/*.so /usr/lib/cp `pwd`/build/*_release/*.so.2 /usr/lib/ldconfigcd ..cd re2c-0.13.5./configure --prefix=`pwd`/../localmake installcd ..cd libevent-1.4.14-stablecp ../hiphop-php/src/third_party/libevent-1.4.14.fb-changes.diff .patch <" libevent-1.4.14.fb-changes.diff./configure --prefix=`pwd`/../localmake installcd ..cd curl-7.20.0cp ../hiphop-php/src/third_party/libcurl.fb-changes.diff .patch -p1 <" libcurl.fb-changes.diff./configure --prefix=`pwd`/../localmake installcd ..cd libmemcached-0.48./configure --prefix=`pwd`/../localmake installcd ..cd icu/source./configure --prefix=`pwd`/../../localmake installcd ../..cd onig-5.9.2./configure --prefix=`pwd`/../localmake installcd ..cd boost_1_50_0./bootstrap.sh --prefix=`pwd`/../local --libdir=`pwd`/../local/lib./bjam --layout=system installexport Boost_LIBRARYDIR=`pwd`/../local/include/boost/cd ..ldconfigcp -r imap local/include/cp /usr/lib/libc-client.so.2007 local/lib/libc-client.socd hiphop-phpgit submodule initgit submodule updateexport HPHP_HOME=`pwd`export HPHP_LIB=`pwd`/bincmake .make 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:
Expert: sarabande replied at 2024-11-13 03:49:54
great. good luck.
Sara
Sara
Author: duncanb7 replied at 2024-11-13 03:21:43
Thanks for your suggestion and elfwriter error is gone
Author: duncanb7 replied at 2024-11-13 03:06:13
Dear sarabande,
g_dwarfCallback call another function of Dwarf_Callback_Func_c
in which I change it from const char * to char * on line 26 in code area, and then
elfwriter.cpp error is gone and thanks for your suggestion, and installation is continuing now and waiting for final result, hope no more error
Dunan
Dunan
bool ElfWriter::initDwarfProducer() { Dwarf_Error error = 0; /* m_dwarfProducer is the handle used for interaction for libdwarf */ m_dwarfProducer = dwarf_producer_init_c( DW_DLC_WRITE | DW_DLC_SIZE_64 | DW_DLC_SYMBOLIC_RELOCATIONS, g_dwarfCallback, nullptr, nullptr, reinterpret_cast<Dwarf_Ptr>(this), &error); if (m_dwarfProducer == reinterpret_cast<Dwarf_P_Debug>(DW_DLV_BADADDR)) { logError("Unable to create dwarf producer"); return false; } return true;}Dwarf_P_Debug dwarf_producer_init_c( Dwarf_Unsigned /*flags*/, Dwarf_Callback_Func_c /*func*/, Dwarf_Handler /*errhand*/, Dwarf_Ptr /*errarg*/, void * /*user_data*/, Dwarf_Error * /*error*/);typedef int (*Dwarf_Callback_Func_c)( const char* /*name*/, int /*size*/, Dwarf_Unsigned /*type*/, Dwarf_Unsigned /*flags*/, Dwarf_Unsigned /*link*/, Dwarf_Unsigned /*info*/, Dwarf_Unsigned* /*sect_name_index*/, void * /*user_data*/, int* /*error*/);extern int g_dwarfCallback(char *name, int size, Dwarf_Unsigned type, Dwarf_Unsigned flags, Dwarf_Unsigned link, Dwarf_Unsigned info, Dwarf_Unsigned *sect_name_index, Dwarf_Ptr handle, int *error); 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:
Author: duncanb7 replied at 2024-11-12 10:43:58
Dear sarabande
thanks for your reply above, please don't look at the Makefile I attached
that is not the right one.
And finally I found the Makefile in which I delete all code
about elfwriter.cpp, and let the hiphop installation to continue without
interuption from error by elfwriter.cpp. Now the installation is almost
finished in 99% without elfwriter.cpp
The Makefile will include other Makefile2 and build and depend on build.make
and depend.make respectively. In build.make, I deteleted all related elfwriter code
as follow in code area. it will aslo do similar work for dwarf.cpp and debug.cpp
hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o: hphp/runtime/CMakeFiles/hphp_runtime_static.dir/flags.makehphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o: hphp/runtime/vm/debug/elfwriter.cpp $(CMAKE_COMMAND) -E cmake_progress_report /home/dev/hiphop/hiphop-php/CMakeFiles $(CMAKE_PROGRESS_406) @$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --green "Building CXX object hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o" cd /home/dev/hiphop/hiphop-php/hphp/runtime && /usr/local/bin/c++ $(CXX_DEFINES) $(CXX_FLAGS) -o CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o -c /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpphphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.i: cmake_force @$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --green "Preprocessing CXX source to CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.i" cd /home/dev/hiphop/hiphop-php/hphp/runtime && /usr/local/bin/c++ $(CXX_DEFINES) $(CXX_FLAGS) -E /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp > CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.ihphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.s: cmake_force @$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --green "Compiling CXX source to assembly CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.s" cd /home/dev/hiphop/hiphop-php/hphp/runtime && /usr/local/bin/c++ $(CXX_DEFINES) $(CXX_FLAGS) -S /home/dev/hiphop/hiphop-php/hphp/runtime/vm/debug/elfwriter.cpp -o CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.s# Object files for target hphp_runtime_statichphp_runtime_static_OBJECTS ="CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o"# External object files for target hphp_runtime_statichphp_runtime_static_EXTERNAL_OBJECTS =hphp/runtime/libhphp_runtime.a: hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o# Rule to build all files generated by this target.hphp/runtime/CMakeFiles/hphp_runtime_static.dir/build: hphp/runtime/libhphp_runtime.a.PHONY : hphp/runtime/CMakeFiles/hphp_runtime_static.dir/buildhphp/runtime/CMakeFiles/hphp_runtime_static.dir/requires: hphp/runtime/CMakeFiles/hphp_runtime_static.dir/vm/debug/elfwriter.cpp.o.requires 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:
I will continue to go the only elfwriter.cpp and compiler it as single standalone CPP file
(with its include file) first to see what error that will reduce debugger time.
Please bring out any suggestion that I can try and test that I will be appreicated
Author: duncanb7 replied at 2024-11-12 07:57:15
Last makefile may not be correct
I resend the file Makefile from hphp/runtime/ directory that
is exact file for running for elfwriter.cpp on
line 8362
line 8362
Author: duncanb7 replied at 2024-11-12 07:33:25
Attached file.
Please advise and appreciated your help
Expert: sarabande replied at 2024-11-12 07:22:36
the function ElfWriter::initDwarfProducer() passes a function pointer g_dwarfCallback to another function. this call back function seems to have a wrong signature what leads to the error. you should looking in the sources where the g_dwarfCallback was defined (perhaps in elfwriter.h).
I cannot install the hiphop as I don't have the right environment. but I can help you with compilation errors. probably the easiest would be if you skip the build (and the copying of the build results) in the installation script. the installation then would succeed and we could start the build manually and do the necessary changes in the source code directly.
alternatively post the makefile and I check how the release build could be called from script. if you are lucky, the build would work for release.
Sara
Sara
Author: duncanb7 replied at 2024-11-12 04:30:10
Are you succesfully to install hiphop on your server before, what is your server
you used ?
There is three files need to copy as follow commands
As you said, it seems the error is from libdawrf.h and elfwriter.cpp ?
RIght? How to fix the file by editing inside of file.
I attached file for your review, please help on it.
you used ?
Expert: sarabande replied at 2024-11-12 03:58:57
it actually is not an installation issue but compile warnings and errors.
the warnings you may ignore (or try to get rid of them by providing compiler flags with the CC that would ignore the warnings).
but the error "invalid conversion from ..." in HPHP::Debug::ElfWriter::initDwarfProducer()’ is severe. here the function tries to assign a function pointer which has a 'char *' as first argument but where a 'const char *' is required. the problem only can be solved in the source beside you could make that the installation builds a release version instead of a debug version. the release build not necessarily has the same issue as the function seems to be a debug only function. same applies for the next error "error: initializing argument 2 of ‘Dwarf_P_Debug_s* dwarf_producer_init_c ..." which obviously also is in a debug function only.
I don't know how to switch from debug to release build but you may look in the 'makefile' of folder libdwarf/libdwarf whether it can be used fro release build. or, you skip the build in the installation and do a manual build after installation where you could solve the issues in the source code.
Sara
Sara
