When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-11 05:37:03
Point:500 Replies:11 POST_ID:828785USER_ID:11059
Linux;C++ Programming Language;C Programming Language
I install boost into my directy with the following linux Centos command
tar xvzf boost_1_50_0.tar.gz
cd boost_1_50_0
./bootstrap.sh --prefix=../local --libdir=../local/lib
./bjam --layout=system install
export Boost_LIBRARYDIR=../local/include/boost/
cd ..
During installation, it will echo a lot of response from the shell as follows in code area
There is a lot character of "^" under the character b of boost.
What is that meaning ? Is it installation error mesage ?
Do I need take care of those response ?
And last question why it took almost 1hour to finish boost installation. Is it normal
installation time?
Please advise and appreciated your help
cd boost_1_50_0
cd ..
installation time?
./boost/spirit/home/classic/phoenix/tuple_helpers.hpp: In function ‘TupleResultT phoenix::convert_actors(const ActorTupleT&)’:./boost/static_assert.hpp:125:21: warning: typedef ‘boost_static_assert_typedef_509’ locally defined but not used [-Wunused-local-typedefs] BOOST_JOIN(boost_static_assert_typedef_, __LINE__) ^./boost/spirit/home/classic/phoenix/tuple_helpers.hpp:509:5: note: in expansion of macro ‘BOOST_STATIC_ASSERT’ BOOST_STATIC_ASSERT(ActorTupleT::length <= TupleResultT::length); ^./boost/spirit/home/classic/phoenix/tuple_helpers.hpp: In static member function ‘static phoenix::impl::convert_actor<N, TupleResultT, ActorTupleT>::type phoenix::impl::convert_actor<N, TupleResultT, ActorTupleT>::actor_element(const ActorTupleT&, phoenix::impl::convert_actor<N, TupleResultT, ActorTupleT>::is_not_default)’:./boost/static_assert.hpp:125:21: warning: typedef ‘boost_static_assert_typedef_536’ locally defined but not used [-Wunused-local-typedefs] BOOST_JOIN(boost_static_assert_typedef_, __LINE__) ^./boost/spirit/home/classic/phoenix/tuple_helpers.hpp:536:13: note: in expansion of macro ‘BOOST_STATIC_ASSERT’ BOOST_STATIC_ASSERT(ActorTupleT::length <= TupleResultT::length); ^./boost/wave/grammars/cpp_chlit_grammar.hpp: In member function ‘void boost::wave::grammars::impl::compose_character_literal::operator()(uint32_t&, bool, bool&, uint32_t) const’:./boost/static_assert.hpp:125:21: warning: typedef ‘boost_static_assert_typedef_85’ locally defined but not used [-Wunused-local-typedefs] BOOST_JOIN(boost_static_assert_typedef_, __LINE__) 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:
Author: duncanb7 replied at 2024-11-13 07:19:11
thanks for you reply
Expert: Mazdajai replied at 2024-11-13 06:53:26
125 points EXCELLENT
The warnings refer to boost_static_assert, try reviewing namespace scopes -
http://www.boost.org/doc/libs/1_54_0/doc/html/boost_staticassert.html
Author: duncanb7 replied at 2024-11-12 02:34:05
I agree it is warning message since if error message it will echo out with a word of "error" normally.
But how I can get rid of those warning after setting gcc compiler option correctly ?
Expert: Mazdajai replied at 2024-11-11 11:19:05
The easiest is to ask your hosting company. But you can look under /proc/meminfo and /proc/cpuinfo.
One hour is unusual, but I cannot really comment on it because I never compile boost from source. (1.41 is in repo).
Author: duncanb7 replied at 2024-11-11 10:57:21
The boost I installed is in my other directory, for example, /home/example/ , which
is for other application to call its library.
I think the boost installation won't affect the first system boost which is installed
by my hosting company , Right ?
Author: duncanb7 replied at 2024-11-11 10:52:24
it is Virturl machine from hosting company
How to check memory and cpu ?
By the way, the version is "unknown" for x86_64-linux-gnu that is okay ?
and x86_64-linux-gnu is C complier, RIght ?
Expert: Mazdajai replied at 2024-11-11 10:49:29
Is this a vm? What about memory and cpu?
Author: duncanb7 replied at 2024-11-11 10:47:06
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/local/libexec/gcc/x86_64-unknown-linux-gnu/4.8.0/lto-wrapper
Target: x86_64-unknown-linux-gnu
Configured with: ../gcc-4.8.0/configure --enable-checking=release --enable-languages=c,c++ --disable-multilib : (reconfigured) ../gcc-4.8.0/configure --enable-checking=release --enable-languages=c,c++ --disable-multilib
Thread model: posix
gcc version 4.8.0 (GCC)
Linux vps.example.com 2.6.32-042stab078.28 #1 SMP Mon Jul 8 10:17:22 MSK 2013 x86_64 x86_64 x86_64 GNU/Linux
COLLECT_GCC=gcc
Thread model: posix
Expert: Mazdajai replied at 2024-11-11 10:41:34
Is boost working? I would say it is safe to ignore unless it is broken. However, if you are not comfortable you can the warning messages to the maintainer / developer.
What is your machine specs? (cpu, mem, vm / physical ..etc) Also post the following -
Author: duncanb7 replied at 2024-11-11 09:49:28
So you mean I just ignore it, don't worry about it, Right ?
a little bit uncomfortable to those long long echo response from the installation
And there is no error.
Is the installation time okay ?
Expert: Mazdajai replied at 2024-11-11 09:33:08
Those appear to be warnings (environment, definition) can be ignored.
Were there any errors in the compile process?
