When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ank5
at 2024-11-04 11:11:07
Point:500 Replies:8 POST_ID:828777USER_ID:11616
JavaScript;Web Languages/Standards;Scripting Languages
I have an Ext JS function in which I was displaying a javascript alert and it worked perfectly fine.
if(matchStatus == false) { alert('Please refine your selection'); return false; } 1:2:3:4:
Now I want to display an Ext JS alert instead of Javascript alert, so I changed the above code to
if(matchStatus == false) { Ext.Msg.alert("Alert", "Please refine your selection");" return false;" } 1:2:3:4:
Now this code does not work. In my UI, I get an blank alert window (please refer to the attached screenshot).
Can someone please help me resolve this problem. Thank you.
Expert: duncanb7 replied at 2024-11-07 11:22:59
Could you send us your file with all link or script file you include
in the html fille , not just function code but also something like as follows
<link rel="stylesheet"type="text/css"
href="lib/extjs/resources/css/ext-all.css"/>
<script src="lib/extjs/adapter/ext/ext-base.js"></script>
<script src="lib/extjs/ext-all-debug.js"></script>
Author: ank5 replied at 2024-11-05 22:04:13
Tried this but it didn't help either
Ext.namespace('m2n');(function() { m2n.getLinkStatus = function(folderObjID, docParentFolderIDs) { var matchStatus = true; folderObjID = folderObjID+""; docParentFolderIDs = docParentFolderIDs+""; var folderObjIDArray = ''; var docParentFolderIDsArray = ''; if(folderObjID != '') { folderObjIDArray = folderObjID.split(','); } if(docParentFolderIDs != '') { docParentFolderIDsArray = docParentFolderIDs.split(','); } for(var i = 0; i < folderObjIDArray.length; i++){ for(var j = 0; j < docParentFolderIDsArray.length; j++){ if(folderObjIDArray[i].indexOf(docParentFolderIDsArray[j]) > -1) { matchStatus = false; } } } if(matchStatus == false) { Ext.onReady(function(){ Ext.MessageBox.alert("Alert1", "Please refine your selection1"); }); return false; } return matchStatus; };})(); 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:
Expert: mikeyd234 replied at 2024-11-05 09:55:08
Also, make sure you've included the default Ext theme / style-sheet on your page. I've forgotten to do it once or twice and things look weird - just like in your screenshot.
Another thing,
Use the the short form like in your first post :D less typing, boo to Ext.MessageBox.alert :)
Another thing,
Expert: duncanb7 replied at 2024-11-05 09:51:52
Yes, mikey, that is typing mistake
Expert: mikeyd234 replied at 2024-11-05 09:42:08
Author: ank5 replied at 2024-11-04 20:48:46
Here is my complete code. This functions is called from UI. The Javascript alert works fine but Ext JS alert doesn't
(function() { m2m.getLinkStatus = function(folderObjID, docParentFolderIDs) { var matchStatus = true; folderObjID = folderObjID+""; docParentFolderIDs = docParentFolderIDs+""; var folderObjIDArray = ''; var docParentFolderIDsArray = ''; if(folderObjID != '') { folderObjIDArray = folderObjID.split(','); } if(docParentFolderIDs != '') { docParentFolderIDsArray = docParentFolderIDs.split(','); // alert('array size docParentFolderIDsArray '+docParentFolderIDsArray.length); } for(var i = 0; i < folderObjIDArray.length; i++){ for(var j = 0; j < docParentFolderIDsArray.length; j++){ if(folderObjIDArray[i].indexOf(docParentFolderIDsArray[j]) > -1) { matchStatus = false; } } } if(matchStatus == false) { // Ext.Msg.alert("Alert", "Please refine your selection"); // alert('Please refine your selection'); Ext.onready(function(){ Ext.MessageBox.alert("Alert", "Please refine your selection"); }); return false; } return matchStatus; };})(); 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:
Also, the below code gives an error in Javascript console
Ext.onready(function(){ Ext.MessageBox.alert("Alert", "Please refine your selection"); }); 1:2:3:
Error is as follows
Expert: Rainer Jeschor replied at 2024-11-04 13:45:55
as this very basic sample:
http://jsfiddle.net/EE_RainerJ/6S68L/
works as expected (and according to your screenshot the alert and the alert title are shown but not the message), I can only think of an issue in regards to the CSS.
Could you perhaps share more of your code or even better provide a link to the page?
Which exact version of Ext JS are you using?
Thanks.
Rainer
Thanks.
Rainer
Expert: duncanb7 replied at 2024-11-04 13:18:49
http://c4learn.com/tutorials/learn-extjs/alert-message-box-in-extjs/
take a look
and try to use
Hope it works
take a look
and try to use
Hope it works
