When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by EESky
at 2024-11-03 11:58:18
Point:500 Replies:4 POST_ID:828775USER_ID:11667
Anti-Virus Applications;;Anti-Spyware
Hi Any experts can solve my problem? it is very strange. When i type word no matter it is on MS WORD or on other web page, my cursor often disappear for about 10 second, so i can not keep typing any word. When it disappear, i have to click my mouse on the right place in order to get the cursor back to right place and keep typing word. Any expert can help solve it ? Thank you !
Author: EESky replied at 2024-11-03 14:00:40
Hi Thank all of you for your reply. @liorkr, i tried it, but it did not work.
@Smighty, the CPU utility is not high, maybe some virus problem
@ duncanb7, so far, i think your way is right. i need to try and wait for a while after shutting down some software.
Expert: Lior Karasenti replied at 2024-11-03 12:20:00
Try change in control panel -> mouse -> pointer options and untick hide pointer when typing
Expert: Smighty replied at 2024-11-03 12:19:44
Since you describe that the problem not only occours in Word, but in your browser as well, I think this may either be a ressource problem or some kind of malware on your machine.
Try disabling/stopping all Software that runs on the machine and check whether or not your system is busy. This is normally shown in Taskmanager - if your CPU is used at 100%, it may explain why it seems to freeze your cursor. (Even short spikes on 100% can be an indicator...)
If its not a ressource problem, your machine might be infected with malware. Please update and scan your machine completely (depending on your AntiVirus Software you can do an offline-Scan as well.)
Expert: duncanb7 replied at 2024-11-03 12:05:54
Could you try disconnect internet and try MS word again to see what happen?
Coud you reboot your window and then go to system safe mode and try
MS word to see what happen? (that I'm not sure you can run MS word at safe mode or not )
Up to this memont based on your limited information, it is hard to tell that
is related to virsu or others
