When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ank5
at 2024-11-03 09:09:25
Point:500 Replies:4 POST_ID:828774USER_ID:11616
JavaScript;Web Languages/Standards;Scripting Languages
I need to write a Javascript function which accepts two comma separated values
(function() { m2.getStatus = function(folderObjIDs, docObjIDs) { };})(); 1:2:3:4:5:6:
Now both these parameters could have multiple values each separated with a comma.
Example, folderObjIDs could have 'a,b,c' and docObjIDs could have 'c,d,e'.
I need to check which value is common in both the parameters, and then alert it to the user ('c' in the example above).
Can someone please let me know how this can be done?
Thank you
Expert: leakim971 replied at 2024-11-03 15:27:54
Uncaught TypeError: Object [object Array] has no method 'split'
that mean you don't pass << two comma separated values >>
m2.getStatus = function(folderObjIDs, docObjIDs) {var f1 = "";var f2 = ""; if(typeof folderObjIDs!="string") { alert("folderObjIDs is not string, hope it's an array..."); f1 = folderObjIDs } else { f1 = folderObjIDs.split(","); } if(typeof docObjIDs!="string") { alert("docObjIDs is not a string, hope it's an array..."); f2 = docObjIDs; } else { f2 = docObjIDs.split(","); } var f3 = []; for(var i=0;i<f1.length;i++) for(var j=0;j<f2.length;j++) if(f1[i]==f2[j]) f3.push(f1[i]); return f3.join(","); }; 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:
Expert: duncanb7 replied at 2024-11-03 12:00:14
Try to use split() function in javascript and its syntax from www.w3schools.com
folderObjIDs ='a,b,c';
array=folderObjIDS.split(",");
alert(array[0]); //// that you can get "a"
so next step will be easier for you for any operation for those two string comparsion
by your javascript function
Author: ank5 replied at 2024-11-03 10:10:37
Thank you. I tried that but it gives me an error
Expert: leakim971 replied at 2024-11-03 09:24:09
test page : http://jsfiddle.net/URzgr/1/
m2.getStatus = function(folderObjIDs, docObjIDs) { var f1 = folderObjIDs.split(","); var f2 = docObjIDs.split(","); var f3 = []; for(var i=0;i<f1.length;i++) for(var j=0;j<f2.length;j++) if(f1[i]==f2[j]) f3.push(f1[i]); return f3.join(","); }; 1:2:3:4:5:6:7:8:9:
