When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by gplana
at 2024-11-02 09:55:58
Point:500 Replies:16 POST_ID:828771USER_ID:11366
Cascading Style Sheets (CSS);Hypertext Markup Language (HTML);jQuery
Hi.
Please look at this site: http://www.gapla.cat/cita-AP/htmlsite
This is a static html page extracted from my project to show you the issue: you can see on the bottom right box a table. The content of the table (the table body, but not the header) should be scrollable. It is working fine on FireFox, but is it not working on Internet Explorer (tested on IE7 and IE9).
Expert: duncanb7 replied at 2024-11-02 11:03:32
I am sorry, I might quit here and just let Gary follow it
Thanks for your reply
have a nice day
have a nice day
Author: gplana replied at 2024-11-02 11:03:21
Excellent. This seems to do the job.
Thank you very much.
Expert: Gary replied at 2024-11-02 11:03:19
Just use the method above with the div, I cannot completely test properly in IE9 but the above will work.
Author: gplana replied at 2024-11-02 10:59:54
GaryC123 styles are now copied to table, but scroll still doesn't work and now also the header row is too high.
Expert: Gary replied at 2024-11-02 10:59:42
If that doesn't work then you will need to wrap your table in a scrollable div e.g.
<div style="height: 357px; display: block; overflow-y: auto;overflow-x:hidden">
<table>
</table>
</div>
<table>
</table>
</div>
Author: gplana replied at 2024-11-02 10:56:28
Sorry guys, but I think we are chatting about another thing. The problem here is to make work that page on IE. Isn't this possible?
Expert: Gary replied at 2024-11-02 10:56:21
@duncanb7
Your comments are nothing to do with the question. Either keep your comments related to the question or do not comment at all.
Expert: Gary replied at 2024-11-02 10:55:39
Move these styles so they are applied to the table and not the tbody
display: block;
height: 357px;
overflow: auto;
display: block;
height: 357px;
overflow: auto;
Expert: duncanb7 replied at 2024-11-02 10:43:28
How do you think which browser is better and faster, GaryC123 ?
After I switch to Chrome, I never experience many technical issue as IE does
And I also gave up FF since FF's latest version is much much slower
than its older version and Chrome.
Even the data just check and based on W3schools server but I think that
is liable if you look at how many users use w3schools daily by Alexa's rank
for global, I believe the stat sample users is larger enough for statistic
Author: gplana replied at 2024-11-02 10:43:20
Sorry, I have to make this page work on IE and Firefox.
Author: gplana replied at 2024-11-02 10:41:08
On firefox is working but n IE9 is not working.
Expert: Gary replied at 2024-11-02 10:40:17
@ duncanb7
That's funny lol
IE usage is around 30% (and increasing) - w3schools stats are not reliable since they measure their own usage which by the very nature of their site is developers who tend to use FF and Chrome.
That's funny lol
Expert: Gary replied at 2024-11-02 10:37:16
Do an hard refresh and you will see it is now working.
Expert: duncanb7 replied at 2024-11-02 10:36:34
http://www.w3schools.com/browsers/browsers_stats.asp
If you look at this browser stat on the link, you can see
IE usage is dropping into 1x % and IE has a lot of
techincal issue,
So I suggest why ask your users switch to Google Chrome instead of
keeping wasting time on IE that I did before and give it up in last two years.
Chrome browser is much faster and stable than Firefox and specially for IE
And I ran you site on my IE that is working for scroll
techincal issue,
Author: gplana replied at 2024-11-02 10:26:41
Thank you for your answer. This seems not to be the problem. I have added the doctype but the issue still stays.
Expert: Gary replied at 2024-11-02 10:22:47
You have no doctype so the page is going into quirks mode, add this to the beginning of your page and it should then work
<!DOCTYPE html>
<!DOCTYPE html>
