When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by sikyala
at 2024-11-01 07:33:53
Point:500 Replies:4 POST_ID:828768USER_ID:11674
MS SQL Server;;Windows 2003 Server
I have text in a field that looks like the following:
Contract_no
AB-123C-4567
DE-892F-
6007
GH-292I-J2006
KL-3434-
M2008
That is actually 4 rows of data. The data was entered for some of the records with what looks like a hard return. When I try to use BCP to export the records and remove the whitespace it doesn't work. How should I fix this?
I tried the following select statement in my export select RTRIM(LTRIM(contract_no)) from contracts
Contract_no
AB-123C-4567
DE-892F-
6007
GH-292I-J2006
KL-3434-
M2008
Author: sikyala replied at 2024-11-07 08:38:09
thanks
Author: sikyala replied at 2024-11-01 07:46:56
I mannually entered the sample data I am viewing it inside of sql server I open the table and look at the field values. Then I export it using bcp the data appears in the text file the same way. I will try the replace argument
Expert: Brian Crowe replied at 2024-11-01 07:42:30
You can try stripping them out of the data using REPLACE. CHAR(10) and CHAR(13) are newline and carriage return characters.
SELECT REPLACE(REPLACE(myColumn, CHAR(13), ''), CHAR(10), '')
Expert: duncanb7 replied at 2024-11-01 07:39:21
where you view the information ?
Contract_no
AB-123C-4567
DE-892F-
6007
GH-292I-J2006
KL-3434-
M2008
You view the data in webpage or in mysql database in phpmyadmin ?
If you view it in html page, you need to
set p tag with CSS
<style>
p
white-space:nowrap;
</style>
take a look for minus-sign in html page
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/CSS/Q_28230776.html
Contract_no
AB-123C-4567
DE-892F-
6007
GH-292I-J2006
KL-3434-
M2008
set p tag with CSS
<style>
p
white-space:nowrap;
</style>
