When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Miguel_G
at 2024-11-01 06:59:26
Point:0 Replies:9 POST_ID:828767USER_ID:11672
Cascading Style Sheets (CSS);;
Hey
Please visit this Page:
http://promenade.no/okonomi/banker
On first Page load, the first Tab content does not render well. There are 3 Columns with text, however there is a gap and some text overlapping issues.
It renders fine after you click on other Tabs and go back to the first Tab.
See attached screenshot.
Can you help fix the issue?
Author: Miguel_G replied at 2024-11-10 02:15:49
that was the only solution that worked!
Author: Miguel_G replied at 2024-11-05 06:47:21
That solution did not work and it was not implemented.
Expert: Gary replied at 2024-11-05 06:42:36
Author: Miguel_G replied at 2024-11-05 06:29:24
I've requested that this question be closed as follows:
Accepted answer: 0 points for Miguel_G's comment #a39624289
for the following reason:
None of the provided solutions had worked.
Issue was fixed using 3rd party JavaScript.
Author: Miguel_G replied at 2024-11-05 06:28:28
Issue has been resolved using JavaScript:
<script type='text/javascript'>jQuery(window).load(function(){jQuery('.tabs_type_2').find('dt:contains("A - F")').trigger('click');});</script> 1:2:3:4:5:
Expert: Gary replied at 2024-11-01 10:00:52
Ignore my comment above, I see what you are trying to do.
You are manually putting class="current" into every block - this should only be on the first block of banks
Expert: Gary replied at 2024-11-01 08:49:59
Stop using position absolute to position elements that should naturally flow.
Move the background image
background-image: url("images/shortcodes/tabs-type2-BG.png");
to the DT element (I presume it should be here and not in
.tabs_type_2 dd {}
But also remove position:absolute from that class (.tabs_type_2 dd {}) and add clear:both
The page will then render somewhat like it should.
.tabs_type_2 dd {}
Expert: duncanb7 replied at 2024-11-01 07:23:50
There are many p tag paragraph broken from one into two paragraph.
You need to set p tag CSS with white-space:nowrap so that
SpareBank 1 Buskerud-Vestfold won't be displayed as
Vestfold
p
white-space:nowrap;
Vestfold
p
white-space:nowrap;
Expert: COBOLdinosaur replied at 2024-11-01 07:11:47
Page with excessive scripting from multipe libraries often end up with conflicts or compatibilities issues.
What you describe is indicative if that and as the page is valid markup, I would suggest that you will have to disable the jquery libraries one at a time to see which one is breaking the page.
Cd&
Cd&
