When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jazzIIIlove
at 2024-10-28 05:24:23
Point:500 Replies:5 POST_ID:828766USER_ID:11670
Cascading Style Sheets (CSS);Web Browsers;Programming for ASP.NET
I am having a problem with IE 9, flickering when transition in page. What to do? css tricks?
Transition is clicking a tab "in" the page, and it flickers. I stop addons and tick software rendering in internet options.
What to do? Any css tricks?
Regards.
Regards.
Author: jazzIIIlove replied at 2024-11-12 07:31:18
solved
Author: jazzIIIlove replied at 2024-11-07 02:51:16
didn't solve the problem ie 9 is still flickering..
Expert: duncanb7 replied at 2024-11-01 05:08:19
What you can do in aternative way is that on every page you can do following
code with display:none and display:block by javascript code and CSS.
Probably it will solve you issue to tkae out the flicker effect
<html>
<script>
body{
display:none;
<style>
</style>
function init(){
document.getElementById('bodyid').style.display="block";
</script>
<body id="bodyid" onload="javascript:init();">
<!---- your html code heree--->
</body>
</html>
<html>
<script>
body{
display:none;
<style>
</style>
function init(){
</script>
</body>
</html>
Author: jazzIIIlove replied at 2024-10-29 01:04:14
It is intranet based, but i will post html and css render of it.
Regards.
Regards.
Expert: COBOLdinosaur replied at 2024-10-28 11:33:58
Post a link to the page so we can see what you have.
Cd&
Cd&
