When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by EESky
at 2024-10-05 21:48:22
Point:500 Replies:7 POST_ID:828763USER_ID:11667
Network Routers;;
Expert
I am configuring ip http on Router 3640. I configured #ip http server and username, password on the router. But when i login to the router through web browser, i got below picture 1 without requesting username and password instead of picture 2. why is it happening ? how to solve it? Thanks
Expert: duncanb7 replied at 2024-10-06 08:10:20
did you get into admin page after reset so that you can clear up everything
or reset everything
Probably you can find those adminstrator password for model of router from
google search with your router model number
For my router, I used "admin" for password after resest that I can access
into admin page and reset everything
or reset everything
Author: EESky replied at 2024-10-06 08:04:03
i just tried it, but it cannot work in this router. so what command can clear cache of the router without rebooting router ?
why did i get response with colorless window (see above third picture) instead of color one( second picture above) when i want to login to the router ?
Expert: duncanb7 replied at 2024-10-06 07:55:42
it should be 'admin' for password and don't input login just let it blank
http://pcsupport.about.com/od/cisco-default-passwords/a/valet-m10-default-password.htm
Be reminded, press the reset button at the back of the cisco router
Author: EESky replied at 2024-10-06 07:38:44
Thank you for your reply. If the username is blank with password "password" it does not work in this router, but after rebooting, it finally works. it looks like the router's cache needs to be cleared. So how to do that without rebooting? What command can be used to clear it ?
Expert: duncanb7 replied at 2024-10-05 23:56:39
250 points GOOD
Let username as blank(no input)
and type password as "password"
that is default password after reset for cisco
and then reset all username and password afer
login inot admin page
Expert: duncanb7 replied at 2024-10-05 23:50:31
250 points GOOD
Could you press reset button on your router for 30 seconds
and try it again ?
and try it again ?
Author: EESky replied at 2024-10-05 22:06:52
After i typed "ip http authentication local" and then i tried to login to the router, i got below picture. But i could never login to the router again.
what i used of command is :
ip http server
username cisco privilege 15 password cisco
