When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-28 04:07:38
Point:500 Replies:13 POST_ID:828756USER_ID:11059
VMware;Virtualization;Windows Server 2008
Recently I have found a word Of VMware and google it for searching its articles.
http://en.wikipedia.org/wiki/VMware
http://finance.yahoo.com/q/pr?s=VMW+Profile
What my understanding is VMware is company helping users to do its
clouding computer networks or access VMware clouding computer networks
to share application software resource with different computer system or network
There is many software for free trial and download
http://www.vmware.com/ap/try-vmware.html
My question is could you make me a concept example or case how VMw works or
what service he provides to the users.
For example, when we are talking about XAMPP server, we will know it is
apache server that be used on Window and Linux , XAMPP can let web users
to set his own computer as web server so that other users can web its home page,
some thing like, So this example is easy to understand what is XAMPP server
Could you make me such example so that for example, when I downoad one software
from VMW, I will understand what is for ? in the link, there are too many software, let
people confused.
Good article and tutorial for the concept of VMW is welcome
people confused.
Expert: Jason Watkins replied at 2024-08-28 06:49:28
Thanks for the points!
Expert: Andrew Hancock replied at 2024-08-28 06:46:26
No problems.
Author: duncanb7 replied at 2024-08-28 06:44:12
Thanks for all of your reply, I will try the software trial first and then
make new thread about other VMware questions
Expert: Andrew Hancock replied at 2024-08-28 06:26:12
300 points EXCELLENT
Yes, this is correct.
The operating system could be Windows, Linux, Unix, Novell, Apple (if running on Apple hardware)
Author: duncanb7 replied at 2024-08-28 06:22:31
VMwarre has VMware player software in which users can host mutilple computers
that means user can run different or many system platforms such as Window xp, window
7, visita at the same time in one single computer from that user seems to connect
to many computer but not in real just by virtually in single computer
Is it correct ?
Is it correct ?
Expert: Andrew Hancock replied at 2024-08-28 06:03:25
VMware - Server, Desktop and Cloud Based Computing.
Expert: Jason Watkins replied at 2024-08-28 05:50:13
VMware does have a sizable cloud component in it's server and VDI products, but to describe them all here is impractical. One of the cloud offering is VDI where desktop computers, running Windows or Linux, can be made available from the cloud in a "Desktop As A Service" platform. VDI is my job at work...
Author: duncanb7 replied at 2024-08-28 05:45:30
From firebar & hanccooka's reply
Is it correct ?
What other major bussinness of VMware is focusing on ? just VMware play is major bussiness to them ?
Is VMware related to clouding computer ?
Please advise kindly
Is it correct ?
Expert: Jason Watkins replied at 2024-08-28 05:19:20
Also, virtualization is used extensively on the server end of IT. Modern server hardware is capable of running multiple, virtualized, operating systems at the same time. One server we have where I work concurrently runs six installs of Windows Server at the same time.
Expert: Andrew Hancock replied at 2024-08-28 05:15:47
You can actually RUN, many computers at a time, on your computer!
using the following:-
VMware Player 5.0 Free Download [FREE]
http://www.vmware.com/go/downloadplayer/
but you still need to use the Operating System original installation media, and have additional Operating System licenses to do it, if required.
e.g. you have a laptop running Windows 7, you can then install VMware Player, and have Windows XP, Windows 8 and Windows Vista all running at the same time.
Expert: Jason Watkins replied at 2024-08-28 05:11:50
200 points EXCELLENT
It is true your laptop may be able to connect to other computers over a network, but that has nothing to do with VMware.
In the case of VMware Player, Server and Workstation, they can run a second operating system, like Windows or Linux, on your Intel computer alongside your existing copy of Windows. This process is called "virtualization". Some people use local virtualization to run software that is not compatible with the copy of Windows natively installed on their computer.
Author: duncanb7 replied at 2024-08-28 04:52:14
VMware produces Hypervisor based software, that allows you to HOST multiple computers, concurrently at the same time on a single Intel computer.
At my home laptap(a single Intel computer) can connect to multiple computer concurrently
at the same time. Is that right ?
What is multiple computers meaning ?Is it my remote servers ?
Why I wil connect to the multiple computers at the same time ? for what application is ?
Expert: Andrew Hancock replied at 2024-08-28 04:46:00
VMware Server 2.0.2 Free Download (discontinued) [FREE]
http://downloads.vmware.com/d/info/datacenter_downloads/vmware_server/2_0
VMware Workstation 9.0 (60 day trial, $199) [EVALUATION]
www.vmware.com/go/downloadworkstation
