When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-15 04:07:01
Point:500 Replies:10 POST_ID:828748USER_ID:11059
PHP Scripting Language;Linux;MySQL Server
I go to root mysql like this
mysql>Show databasese
Database
memberlist
phonelist
wordpress-wp
So there are three databases, First two databases that is okay which
I used phpmyadmin in Cpanel to create them and I can access those two database
by the following php code but fail on database of "wordpress-wp";
Now I expired Cpanel , so I could not use CPanel any more, so I need to use shell command to create my wordpress-wp that is okay & I can access & use it on wordpress software .
But when I try access the database of wordpress-wp using following php
cod ing , that is not working even I already grant access right for my user account
on wordpress-wp, I can not pass the mysql_select_db("wordpress-wp"), Why ?
So I go recheck again at mysql with command Show Grants for myloginname
that also show I have right on the database , wordpress-wp
Now I can see my database is there at /var/lib/mysql but my.cnf file is emtry
at /etc/ so, could you also tell where is mysql config setup file in which
I can see mysql will go to locate the database to /var/lib/mysql ?
Pleae advise, and mysql_connect is no issue at all and I can access wordpress-wp at
linux shell and passed "use wordpress-wp" & "Select * from wp_posts where 1"
I guess that is related path redirect or alias issue on linux , and actual mysql
database path might Not be at /var/lib/mysql but I could NOt find out the solution
of this thread
Database
memberlist
phonelist
wordpress-wp
of this thread
<?php $link = mysql_connect(http://mysite.com:3306, DB_USER, DB_PASSWORD); if(!$link) { die('Failed to connect to server: ' . mysql_error()); } $db = mysql_select_db("wordpress-wp"); if(!$db) { die("Unable to select database"); } 1:2:3:4:5:6:7:8:9:
Expert: julianH replied at 2024-08-15 06:08:04
Yes that would explain it you could also have tried this
Otherwise you are welcome and thanks for the points.
Author: duncanb7 replied at 2024-08-15 05:48:08
The wordpress login is created at mysql with "@localhost"
The userlogin is created by adduser for SSH shell
change from
define("DB_HOST", "http:mysite.com:3306");
to
define("DB_HOST", "localhost:3306");
that is working and wordpress-wp is accesed by mysql_select_db in php coding
change from
to
Author: duncanb7 replied at 2024-08-15 05:34:52
mysql>GRANT ALL PRIVILEGES ON wordpress-wp TO userlogin@localhost IDENTIFIED BY 'password'
Author: duncanb7 replied at 2024-08-15 05:31:18
different password and login
But I already grant the right for my userlogin and wordpresslogin account on "wordpress-wp"
Expert: julianH replied at 2024-08-15 05:20:02
Are you using the same credentials in your PHP script as you have set in your wp-config file?
Author: duncanb7 replied at 2024-08-15 05:16:57
I 'm using following code to get number of database for my loginname
$db_list = mysql_list_dbs($link);
$i = 0;
$cnt = mysql_num_rows($db_list);
while ($i < $cnt) {
echo mysql_db_name($db_list, $i) . "<br>";
$i++;
the result is two
memberlist
phonelist
And no show with "wordpress-wp"
all three is list(ls -la) at /var/lib/mysql
$i = 0;
while ($i < $cnt) {
$i++;
the result is two
memberlist
phonelist
Author: duncanb7 replied at 2024-08-15 05:05:15
OR mysql need to update database list for http request ?
I run the php code on browser and on linux shell running the php code
that is also NOT working
Or OR mysql need to update database list for php,ini ?
Author: duncanb7 replied at 2024-08-15 05:02:37
I try to netstat -tapn and
the port of 3306 is active or listen, of course, since first two database is accesed
and it is using mysqld not mysql
Author: duncanb7 replied at 2024-08-15 04:59:23
Yes,
I can access wordpress software with database of "wordpress-wp"
I can access mysql throught linux shell and use wordpress-wp database
for example
mysql>USE wordpress-wp
mysql>Select * from wp_posts where 1;
--- showing all result
But I can not use in the php coding and report me error as Uable to select database
if(!$db) {
for example
if(!$db) {
Expert: julianH replied at 2024-08-15 04:45:52
So you are saying the posted code fails but you can still access the site through Word Press - is that correct?
