When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-14 09:49:52
Point:500 Replies:9 POST_ID:828746USER_ID:11059
Linux;PHP Scripting Language;Apache Web Server
I would like to set permission control on my server for user on Linux CentOS6
Anyone know it from this tutorial link,
http://www.computerhope.com/unix/uchmod.htm
dxxxyyyzzz, Where d is directory, xxx for server owner, yyy for group user, zzzz for outside users.
When I did " chmod 700 mydir" on linux shell that I want to let my own only
access the mydir for r,w,x permsision and other users in internet could not access this directory
But I tried it on my browser as users and other one can access this directory's index.php.
Why after 700 change, all users can access these diretory?
I thought the issue might be caused by different distribution of Linux such as Centos
It might be not
dxxxyyyzzz or it should be dzzzyyyxxx,
But when I tried "chmod 007 mydir", all users and I (am the owner) that can
Not access the directory's index.php Why ?
And last question, even I can not control group user access , Why and how ?
It might be not
Author: duncanb7 replied at 2024-08-15 03:06:47
Yes, it is correct and thanks
Expert: RitBit replied at 2024-08-15 02:56:51
For a webserver (apache) anyone browsing your site is getting the same user-permissions as your webserver, so if you allow your webserver to access a file, the whole world can access that file. So it's way better to protect files using the webserver configuration, either by the configfiles or a local .htaccess file where you can deny/allow access to a file or directory. You can also specify ipadresses or users (if you use authentication), and you can also completely disable the automatic indexing if you like:
<Files private.html>
Order allow,deny
Deny from all
</Files>
or
<Directory /var/web/dir1>
Order allow,deny
Deny from all
</Directory>
or to disable indexing:
Options -Indexes
</Directory>
See http://httpd.apache.org/docs/2.2/howto/access.html
or https://httpd.apache.org/docs/2.2/sections.html
But another thing you can check is for file ACL parameters as well as they overrule the standard owner-group-other settings on a file.
Use: getfacl <filename> for that.
and use setfacl to change the acl rules on a file.
Order allow,deny
Deny from all
</Files>
or
Order allow,deny
Deny from all
</Directory>
Options -Indexes
</Directory>
Author: duncanb7 replied at 2024-08-14 20:32:34
and I have checked on SSH shell,
that is okay when I set 700 on one directory, other users can NOT access the directory on
SSH shell, so the system format permisision should be duuuyyyzzz, where d is directory, uuu for server owner, yyy for group user, zzzz for outside users.
But why when I go to browser, I still access the index page of that directory that be changed
already to 700 ?
So on SSH shell user control permission works but it doesn't control it on browser
for my case
already to 700 ?
for my case
Author: duncanb7 replied at 2024-08-14 19:53:32
drwx------ 2 mysite mysite 4096 jule 28 01:10 yy/
Expert: _jesper_ replied at 2024-08-14 12:01:39
What is the result of:
chmod 700 mysite; ls -ld mysite
Author: duncanb7 replied at 2024-08-14 10:40:44
yes
Expert: _jesper_ replied at 2024-08-14 10:39:49
Are you logged in as user "mysite"?
Author: duncanb7 replied at 2024-08-14 10:27:35
juts report as follows
drwxrwxrwx 2 mysite mysite 4096 Jul 28 01:10
What is wrong this, and ls -ld?
Expert: _jesper_ replied at 2024-08-14 10:22:31
please do an:
ls -ld <your directory>
ls -ld <your directory/public www directory>
