When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by maroulator
at 2024-08-12 19:59:19
Point:500 Replies:4 POST_ID:828740USER_ID:10
To whom it may concern,
This questions on the graph in the attached spreadsheet.
Is there a way to re-arrange the counterparty names on the Y-axis in alphabetical or reverse alphabetical order by only playing directly with the graph and WITHOUT touching the source table?
Thanks in advance,
-Maroulator
Thanks in advance,
-Maroulator
Attachment:Example.xlsx
Expert: Saqib Husain, Syed replied at 2024-08-15 20:47:41
For future questions please keep this in mind that "Cannot be done" is a very valid response and just because it does not help you as desired does not mean that it should be graded low. Usually a B grade is given when the answer is not complete and needs more work/research to complete it.
Expert: duncanb7 replied at 2024-08-12 23:38:04
now I understood the question, ssaqibh is correct and only way to do that on Excel cell.
You can also lock the graph on VBA if need
Expert: Saqib Husain, Syed replied at 2024-08-12 23:31:26
The graph will follow the same order of the data. You can not sort it separately. You might like to consider a dummy range which picks data from the source table and from which the graph is plotted.
Expert: duncanb7 replied at 2024-08-12 23:03:06
there is a button for alphabetical order or reverse order in excel sheet, did you use it ?
http://office.tizag.com/excelTutorial/excelsorting.php
Or do you want to do it on VBA? please specifiy in thread tag or topic .
Or write it clearly what you want
