When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-10 10:33:51
Point:500 Replies:16 POST_ID:828732USER_ID:11059
WordPress;PHP Scripting Language;Cascading Style Sheets (CSS)
As we know , when we use wordpress editor for paragraph, it will create or add
<p> and <br><br/> tag for each paragraph that will let line-spacing between
two paragraph increase.
How to delete the line-spacing between two paragraph ?
Now I am using wordpress 3.6 with theme twentythirteen
http://www.ehow.com/how_8651230_fix-wordpress-spacing.html
Now I follow the above link to solve the <p> tag line-spacing issue by
editing editor-style.css from the theme's CSS directory, for example,
p{
line-height:0px;
But still not know how to delete or reduce the <br><br/> line-spacing
I tried
br{
display:none;
line-height:0px;
visibility:hidden;
But all is not working for br tag, and I also tried the following link suggested methed
http://urbangiraffe.com/plugins/disable-wpautop/ that is also not working
p{
line-height:0px;
I tried
br{
display:none;
line-height:0px;
visibility:hidden;
Author: duncanb7 replied at 2024-08-16 20:23:07
Thanks for all of your reply, the solution is solved in other threads
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/Q_28209694.html
Expert: heritshah replied at 2024-08-13 02:14:27
167 points EXCELLENT
Hi Duncan!
If i assumed your problem correctly, Here's your solution =>
To just avoid extra (unintentional) line spacing, Simply press Shift + Enter. That should do it. secondly you can just switch to HTML view and manually remove BR between paragraphs. Btw check out "/wp-admin/js/editor.js", and search for <br /> and line break. there are multiple options which you can set to false or true. That might definitely work out for you.
To automate this hack, simply Install this plugin, and you are set to go!
Plugin: http://wordpress.org/plugins/wpautop-control/ (the previous plugin didn't work for you, so you can give it a shot!)
Additional Source: http://rubayathasan.com/wordpress/plugin/enabling-line-break-in-wordpress/
Herit
Herit
Author: duncanb7 replied at 2024-08-10 12:46:44
Please advise kindly
Expert: Ray Paseur replied at 2024-08-10 12:42:20
166 points EXCELLENT
No points for this, please, but there are some important CSS fundamentals you might want to learn about. SitePoint is usually a good place to start learning. Reading other people's CSS files is not a good place to start learning because you do not get the benefit of the strategy, you only see the outcome and you do not know what they were thinking.
http://reference.sitepoint.com/css
Author: duncanb7 replied at 2024-08-10 12:19:18
SOrry, I can not get it
As I know display:block that is display to viewer and occupy display area,
and visibility:hidden that doesn't occupy display area
Why you alway said display:block not display:none that I want to disappear the <br> tage?
Expert: Jason C. Levine replied at 2024-08-10 12:10:36
Br is an inline element (technically a special element) so it doesn't respond respond the same way as p or h or div tags do.
If you attempt to issue block commands on an inline element, they will be ignored.
You either have to figure out a different solution or approach, live with br the way it is, or attempt to force it into a block by issuing
to the tag.
Note that the last suggestion is a pretty big hack and won't work the same way in all browsers.
Author: duncanb7 replied at 2024-08-10 12:01:17
Please write it cleary and simple, I might not get you
Expert: Jason C. Levine replied at 2024-08-10 11:59:13
Know how I know you didn't read or understand my last post?
Author: duncanb7 replied at 2024-08-10 11:55:28
Typing mistake, that should be display:none;
br
display:none;
br
display:none;
Author: duncanb7 replied at 2024-08-10 11:53:27
I Tried
br
display:none;
beofre that is only working on my Window apache Xampp
but on my Centos Linux is not working
br
display:none;
Expert: Jason C. Levine replied at 2024-08-10 11:47:07
Okay, clarification time...
Are you attempting to control the display on the front end or in the TinyMCE editor?
Also,
That's partially true. It's an inline element (technically a special element) so it doesn't respond respond the same way as p or h or div tags do. If you attempt to issue block commands on an inline element, they will be ignored. You either have to figure out a different solution or approach, live with br the way it is, or attempt to force it into a block by issuing display: block !important to the tag. Note that the last suggestion is a pretty big hack and won't work the same way in all browsers.
Also,
<br> tag CSS is not easy to control or limited
Author: duncanb7 replied at 2024-08-10 11:36:22
And
<br> tag CSS is not easy to control and is limited
Author: duncanb7 replied at 2024-08-10 11:33:21
it seem there is NO such CSS from editor-style.css file
div p{
div br{
div p{
div br{
/*Theme Name: Twenty TwelveDescription: Used to style the TinyMCE editor.*/html { font-size: 87.5%;}html .mceContentBody { max-width: 625px;}body { color: #444; font-family: "Open Sans", Helvetica, Arial, sans-serif; font-size: 14px; font-size: 1rem; line-height: 1; text-rendering: optimizeLegibility; vertical-align: baseline;}/* =Headings-------------------------------------------------------------- */h1,h2,h3,h4,h5,h6 { clear: both; line-height: 1.846153846; margin: 24px 0; margin: 1.714285714rem 0;}h1 { font-size: 21px; font-size: 1.5rem; line-height: 1.5;}h2 { font-size: 18px; font-size: 1.285714286rem; line-height: 1.6;}h3 { font-size: 16px; font-size: 1.142857143rem;}h4 { font-size: 14px; font-size: 1rem;}h5 { font-size: 13px; font-size: 0.928571429rem;}h6 { font-size: 12px; font-size: 0.857142857rem;}hr { background-color: #ccc; border: 0; height: 1px; margin: 24px; margin-bottom: 1.714285714rem;}/* =Text elements-------------------------------------------------------------- */p { line-height: 1.714285714; margin: 0 0 24px; margin: 0 0 1.714285714rem;}ul,ol { margin: 0 0 24px; margin: 0 0 1.714285714rem; line-height: 1.714285714; padding: 0;}ul { list-style: disc outside;}ol { list-style: decimal outside;}ul ul,ol ol,ul ol,ol ul { margin-bottom: 0;}li { margin: 0 0 0 24px; margin: 0 0 0 1.714285714rem;}dl { margin: 0 24px; margin: 0 1.714285714rem;}dt { font-weight: bold; margin-bottom: 24px; margin-bottom: 1.714285714rem;}dd { line-height: 1.714285714; margin: 0 0 24px; margin: 0 0 1.714285714rem;}strong { font-weight: bold;}cite,em,i { font-style: italic;}cite { border: none;}big { font-size: 128.571429%;}.mceContentBody blockquote { font-style: italic !important; font-weight: normal; margin: 0; padding: 24px; padding: 1.714285714rem;}pre { border: 1px solid #ededed; color: #666; font-family: Consolas, Monaco, Lucida Console, monospace; font-size: 12px; font-size: 0.857142857rem; line-height: 1.714285714; margin: 24px 0; margin: 1.714285714rem 0; overflow: auto; padding: 24px; padding: 1.714285714rem;}code,kbd,samp,var { font-family: Consolas, Monaco, Lucida Console, monospace; font-size: 12px; font-size: 0.857142857rem; line-height: 2;}abbr,acronym,dfn { border-bottom: 1px dotted #666; cursor: help;}address { display: block; line-height: 1.714285714; margin: 0 0 24px; margin: 0 0 1.714285714rem;}del { color: #333;}ins { background: #fff9c0; border: none; color: #333; text-decoration: none;}sup,sub { font-size: 75%; line-height: 0; position: relative; vertical-align: baseline;}sup { top: -0.5em;}sub { bottom: -0.25em;}input[type="text"] { border: 1px solid #ccc; border-radius: 3px; font-family: inherit; padding: 6px; padding: 0.428571429rem;}textarea { border: 1px solid #d5d2ca; border-radius: 3px; font-family: inherit; font-size: 12px; font-size: 0.857142857rem; line-height: 1.714285714; padding: 10px; padding: 0.714285714rem; width: 96%;}/* =Links-------------------------------------------------------------- */a,a em,a strong { color: #21759b; outline: none;}a:focus,a:active,a:hover { color: #0f3647;}/* =Alignment-------------------------------------------------------------- */.alignleft { display: inline; float: left; margin: 12px 24px 12px 0; margin: 0.857142857rem 1.714285714rem 0.857142857rem 0;}.alignright { display: inline; float: right; margin: 12px 0 12px 24px; margin: 0.857142857rem 0 0.857142857rem 1.714285714rem;}.aligncenter { clear: both; display: block; margin-top: 12px; margin-top: 0.857142857rem; margin-bottom: 12px; margin-bottom: 0.857142857rem;}/* =Tables-------------------------------------------------------------- */table { border-bottom: 1px solid #ededed; border-collapse: collapse; border-spacing: 0; color: #757575; font-size: 12px; font-size: 0.857142857rem; line-height: 2; margin: 0 0 24px; margin: 0 0 1.714285714rem; width: 100%;}tr th { color: #636363; font-size: 11px; font-size: 0.785714286rem; font-weight: bold; line-height: 2.181818182; text-align: left; text-transform: uppercase;}td { border-top: 1px solid #ededed !important; color: #757575; font-size: inherit; font-weight: normal; padding: 6px 10px 6px 0; text-align: left;}/* =Images-------------------------------------------------------------- */img,.editor-attachment { border: 0; border-radius: 3px; box-shadow: 0 1px 4px rgba(0, 0, 0, 0.2); max-width: 100%;}img.size-full { width: auto/9; /* Prevent stretching of full-size images in IE8 */}img[class*="wp-image-"] { height: auto; max-width: 100%;}img[class*="align"],img[class*="wp-image-"],img[class*="attachment-"] { height: auto; /* Make sure images with WordPress-added height and width attributes are scaled correctly */}img.mce-wp-nextpage { border-radius: 0; box-shadow: none;}img.wp-smiley { border: 0; border-radius: 0; box-shadow: none; margin-bottom: 0; margin-top: 0; padding: 0;}.wp-caption { background: transparent; border: none; margin: 0; padding: 4px; text-align: left;}.wp-caption-dt { margin: 0;}.wp-caption .wp-caption-text,.wp-caption-dd { color: #757575; font-style: italic; font-size: 12px; font-size: 0.857142857rem; line-height: 2; margin: 0 0 24px; margin: 0 0 1.71429rem;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:102:103:104:105:106:107:108:109:110:111:112:113:114:115:116:117:118:119:120:121:122:123:124:125:126:127:128:129:130:131:132:133:134:135:136:137:138:139:140:141:142:143:144:145:146:147:148:149:150:151:152:153:154:155:156:157:158:159:160:161:162:163:164:165:166:167:168:169:170:171:172:173:174:175:176:177:178:179:180:181:182:183:184:185:186:187:188:189:190:191:192:193:194:195:196:197:198:199:200:201:202:203:204:205:206:207:208:209:210:211:212:213:214:215:216:217:218:219:220:221:222:223:224:225:226:227:228:229:230:231:232:233:234:235:236:237:238:239:240:241:242:243:244:245:246:247:248:249:250:251:252:253:254:255:256:257:258:259:260:261:262:263:264:265:266:267:268:269:270:271:272:273:274:275:276:277:278:279:280:281:282:283:284:285:286:287:288:289:290:291:292:293:294:295:296:297:298:299:300:301:302:303:304:305:306:307:308:309:310:311:312:313:314:315:316:317:318:319:320:321:322:323:324:325:326:327:328:329:330:331:332:333:334:335:336:337:338:339:340:341:342:
Expert: Jason C. Levine replied at 2024-08-10 11:30:28
Couldn't tell you without seeing a live page to inspect the CSS. The short answer is you likely did something wrong.
Author: duncanb7 replied at 2024-08-10 11:28:07
If as you said, why p tag is working but br tag is NOT working
Expert: Jason C. Levine replied at 2024-08-10 11:24:57
You need to look at the whole CSS tree for the p and br elements. There is likely another line-height declaration higher up in the tree, such as a container div or even the body tag, that is in play.
The other problem is that any line break or paragraph break will have some form of height on it due to the browser. Maybe a link or screenshot that illustrates your issue would help?
