When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by mokkan
at 2024-08-09 06:31:45
Point:500 Replies:4 POST_ID:828729USER_ID:11612
Linux;;Unix Operating Systems
When I look at iptables, i can see lots of rules as default, but when I do iptables -L, it shows only the following line only. Am I missing some thing?
DROP tcp -- 192.168.112.25 anywhere tcp dpt:ssh
[root@server3 init.d]# cat /etc/sysconfig/iptables
# Generated by iptables-save v1.4.7 on Sun Aug 4 00:11:30 2013
*nat
:PREROUTING ACCEPT [134:10773]
:POSTROUTING ACCEPT [333:35516]
:OUTPUT ACCEPT [350:37659]
-A POSTROUTING -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p tcp -j MASQUERADE --to-ports 1024-65535
-A POSTROUTING -s 192.168.122.0/24 ! -d 192.168.122.0/24 -p udp -j MASQUERADE --to-ports 1024-65535
-A POSTROUTING -s 192.168.122.0/24 ! -d 192.168.122.0/24 -j MASQUERADE
COMMIT
# Completed on Sun Aug 4 00:11:30 2013
*mangle
:PREROUTING ACCEPT [57821:26615023]
:INPUT ACCEPT [57814:26614317]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [50045:72013933]
:POSTROUTING ACCEPT [50501:72086655]
-A POSTROUTING -o virbr0 -p udp -m udp --dport 68 -j CHECKSUM --checksum-fill
COMMIT
*filter
:INPUT ACCEPT [89:7135]
:OUTPUT ACCEPT [75:7234]
-A INPUT -s 192.168.112.25/32 -p tcp -m tcp --dport 22 -j DROP
COMMIT
[root@server3 init.d]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
*nat
COMMIT
*mangle
COMMIT
*filter
COMMIT
Author: mokkan replied at 2024-08-09 07:43:43
I found the reason. When I do iptables -L , it only shoes the filter type. I need to check other types to see all the values in iptables such as mangel, raw and nat.
Thank you for your help.
Expert: duncanb7 replied at 2024-08-09 07:27:08
I think you need to re-installip talbes if you could not see it, please see the second link
Author: mokkan replied at 2024-08-09 07:16:45
thank you for your reply. My question is that why it is not showing up when I do iptables -L ?
Expert: duncanb7 replied at 2024-08-09 06:37:20
