When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Geekamo
at 2024-08-09 01:06:02
Point:500 Replies:5 POST_ID:828720USER_ID:11618
Hello Experts,
Please see attached file.
In my master file, I have a column that has time and date/time values.
IE:
3:34:25 AM
5:03:11 PM
1/2/1900 10:24:19 AM
I am looking for a formula, that will look at those values - whether it's just a time or date & time value - and make ALL the seconds show as "00".
Based on the values above,... I would like to see these as the answers.
3:34:00
17:03:00
58:24:00
I had first attempted to use the =FLOOR function, IE : =FLOOR(D433,1/1440)
The majority of the time, that formula would change all seconds to "00". But I also noticed that on 'some' times, even if the time already was at "00" seconds, it would then subtract a minute off of the time. So once I seen that happening, I stopped using the floor function.
I then moved on to using this formula - IE =TIME(HOUR(B4),MINUTE(B4),SECOND("00"))
Which was great, because it forced all times to have "00" seconds. But I noticed those time values would never exceed 24 hours.
So basically it all boils down to this...
I am hoping to get a FORMULA (NOT CELL FORMATTING) that will change all seconds to "00" and allow for the number to exceed 24 hours.
Incase you ask, I'm NOT looking for the seconds to be "ROUNDED" one way or another. Regardless of what the seconds are, they should all be "00".
I hope this all made sense, I am sooooooo frusted that I wasn't able to figure this out tonight. I've spent hours on this so far troubleshooting... :::sigh::: Help, please help! lol
Thanks,
~ Geekamo
IE:
3:34:25 AM
5:03:11 PM
3:34:00
17:03:00
58:24:00
Thanks,
~ Geekamo
Attachment:timehelp.xlsx
Expert: teylyn replied at 2024-08-09 02:59:23
Thanks for the grade, Geekamo. Always glad to help.
Author: Geekamo replied at 2024-08-09 02:52:28
@ All,
Thank you all for your solutions & fast response!
@ teylyn,
Uh, I was so close! :-) Your solution worked flawlessly! Thank you so much!
~ Geekamo
@ teylyn,
~ Geekamo
Expert: teylyn replied at 2024-08-09 01:25:52
Hello,
you almost had it with your own formula in cell B11. Just add the number of days from the source date, like
=DAY(B4)+TIME(HOUR(B4),MINUTE(B4),0)
or starting with the original cell value in B3 works as well.
=DAY(B3)+TIME(HOUR(B3),MINUTE(B3),0)
Keep the cell formatting at [h]:mm:ss. The value is still a true time value, and not text (like the suggestions above), so you can still use it in calculations.
cheers, teylyn
cheers, teylyn
Expert: Rgonzo1971 replied at 2024-08-09 01:18:35
pls try
=TEXT(A1,"[hh]:mm")&":00"
Regards
pls try
Regards
Expert: duncanb7 replied at 2024-08-09 01:09:34
=TEXT(A1,"hh:mm:ss") where cell A1 = 03:34:25 AM
it wil become 03:34:25
And the 1/2/1900 10:24:19 AM is wrong date or true date
