When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by mokkan
at 2024-08-08 07:42:47
Point:500 Replies:9 POST_ID:828715USER_ID:11612
Linux;;Unix Operating Systems
Hello,
If we disable or enable selinux. Do we need to reboot the server?
Author: mokkan replied at 2024-08-11 16:35:07
Thanks a lot.
Expert: _jesper_ replied at 2024-08-08 14:41:01
84 points EXCELLENT
The idea behind 'setenforce' is that is does not require a reboot.
Expert: Mazdajai replied at 2024-08-08 14:23:20
83 points EXCELLENT
To clarify post 39393785 -
setenforce 0 put it in Permissive but not disable it. Edit /etc/selinux/config and reboot the system to disable it. It is recommended to put it in permissive instead. (setenforce 0)
$ less /etc/selinux/config# This file controls the state of SELinux on the system.# SELINUX= can take one of these three values:# enforcing - SELinux security policy is enforced.# permissive - SELinux prints warnings instead of enforcing.# disabled - No SELinux policy is loaded.SELINUX=enforcing# SELINUXTYPE= can take one of these two values:# targeted - Targeted processes are protected,# mls - Multi Level Security protection.SELINUXTYPE=targeted 1:2:3:4:5:6:7:8:9:10:11:12:
Expert: _jesper_ replied at 2024-08-08 10:29:40
83 points EXCELLENT
setenforce 1 => enables
setenforce 0 => disables
'getenforce' gives you the status.
Author: mokkan replied at 2024-08-08 08:35:45
I changed it and still showing as enabled.
[root@server3 ~]# echo 0 > /selinux/enforce
[root@server3 ~]# sestatus
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: permissive
Mode from config file: permissive
Policy version: 24
Policy from config file: targeted
[root@server3 ~]# setenfroce 0
-bash: setenfroce: command not found
[root@server3 ~]# setenforce 0
Policy version: 24
Policy version: 24
Policy version: 24
Expert: _jesper_ replied at 2024-08-08 08:29:07
83 points EXCELLENT
When I've used that command, it's immediate.
Author: mokkan replied at 2024-08-08 08:24:09
once you enabled on live system, by using setenforce 1, would it affect right a way? need few hours to complete?
Expert: _jesper_ replied at 2024-08-08 08:20:50
83 points EXCELLENT
Use 'setenforce' to change your running status.
Expert: duncanb7 replied at 2024-08-08 07:49:46
84 points EXCELLENT
Hope it will help , both article said need to reboot
http://www.revsys.com/writings/quicktips/turn-off-selinux.html
http://www.crypt.gen.nz/selinux/disable_selinux.html
You will need to reboot your system or temporarily set SELinux to non-enforcing mode to create the desired effect like the example above.
You will have to reboot to disable SELinux, you just can't do it while the system is running.
